12-29-2021, 11:23 AM | #1 |
***SOLD***Reconditioned '48-'52 ford f-1 brakes self-energizing & self-adjusting
City:
Oakdale
State:
MINNESOTA
Price:
$310.00
$310 plus shipping Set of '48-'52 F-1 Ford Bendix brakes. Good brake upgrade for early Fords. Fit '37-'48 spindles with an inner bearing change ('37-'41 spindles require a slight clearance grind) . Also fit the earlier '28-'36 spindles with the addition of a common "juice brake" adapter kit. I also include directions for the swap. Backing plates have been reconditioned, sandblasted, and primed. The brakes are assembled with new riveted shoes, wheel cylinders, and self-adjusting hardware. The hubs were fitted with new studs and have been cleaned, blasted, and primed. A set of used F-1 bearings (good for mock-up) are included along with eight original square head mounting bolts. Late model truck drums fit and are readily available from your local auto parts store. The bolt pattern is stock Ford 5 on 5-1/2". $310.00 plus shipping Last edited by rich b; 01-01-2022 at 12:04 PM. Reason: sold |
