Old 11-11-2012, 02:12 PM   #1
Christoph
Christoph's Avatar
Default Fuel Shut Off Valve leaking
Might have been our last cruise 2012 today
Cold but dry again and still no salt on streets so ...
( half of an hour to get motor running propper as still on W50 oil ).
We had a good time out there, but -
Fuel shut off valve (inside under dash) is leaking
Any ideas how to fix or just buy a new one (leak-free) ???
Thank you
Christoph
Christoph is offline   Reply With Quote
Old 11-11-2012, 02:21 PM   #2
160B
160B's Avatar
Default Re: Fuel Shut Off Valve leaking
The design of the valve is a plug valve. I built a tapered cast iron lapping tool to lap the seat and tried skin cutting the plug, not worth the time and limited success. I just buy a new one and replace them.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 11-11-2012, 02:25 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I lapped mine with toothpaste and installed new packing. It turns easy and hasn't leaked a drop in 10 years. I like to keep original parts whenever possible.
Old 11-11-2012, 02:31 PM   #4
AlanD
I wonder if the originals hold up better. I had to replace mine like in the above post. I tried lapping it and new packing but eventually leaked again.
I was told there's something about a tiny groove that gets scratched between the in and out ports and keeps leaking.
I have two leaky valves under the bench.
AlanD is offline   Reply With Quote
Old 11-11-2012, 02:50 PM   #5
Tom Wesenberg
I always install the fine mess screen in the valve. It will help to keep any junk from scratching the valve.
Old 11-11-2012, 03:03 PM   #6
Christoph
Christoph's Avatar
Thank you a lot.
As it came suddenly, i imagine just a prob with the packing .
Tom is my hero - Even as toothpaste-prices rose dramaticly
over here (buhuuu ) i will try ...
Thank you again
Christoph
Old 11-11-2012, 07:20 PM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Originally Posted by Christoph View Post
Thank you a lot.
Thank you again
Christoph
Christof,
You should see the price of HAIR SPRAY here! Hope DEODORANT doesn't go UP!! Fuzzy.
"THE ASSISTANT GURU OF STUFF"
