Old 07-14-2016, 01:07 PM   #1
John cruzin 40
Cool electic inline fuel pump
hi dose anyone know where get an 6v pos. gnd. inline fuel pump for a 42 flat head A B john
John cruzin 40 is offline   Reply With Quote
Old 07-14-2016, 01:17 PM   #2
buelligan
buelligan's Avatar
Default Re: electic inline fuel pump
Carter makes one, (P4259) I am running in my '40, got it from my local NAPA store cheaper than the inner-Web. You will need a regulator.
buelligan is offline   Reply With Quote
Old 07-14-2016, 01:26 PM   #3
John cruzin 40
thank you i was looking at the one just was not sure thanks again John
Old 07-14-2016, 01:26 PM   #4
funrunr
funrunr's Avatar
try www.rockauto.com , like buelligan mentions above, you will need a regulator.
Thank God
this is only a hobby!
funrunr is offline   Reply With Quote
Old 07-14-2016, 01:33 PM   #5
John cruzin 40
thank you funrunr
Old 07-14-2016, 01:58 PM   #6
37 Cab
37 Cab's Avatar
I bought an airtex from Macs. Super quiet and does not need a regulator.
http://www.macsautoparts.com/ford_me...d-mercury.html
Tommy
37 Cab is offline   Reply With Quote
Old 07-14-2016, 02:01 PM   #7
John cruzin 40
thanks Tommy
Old 07-14-2016, 03:26 PM   #8
CarlG
CarlG's Avatar
Snyder's:
http://www.snydersantiqueauto.com/electronic-fuel-pump
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-14-2016, 03:35 PM   #9
weemark
Summit racing sell those pumps for about half the price macs does
https://www.summitracing.com/int/par...0504/overview/
weemark is offline   Reply With Quote
Old 07-14-2016, 04:06 PM   #10
JSeery
JSeery's Avatar
Believe that pump is 12v. The others are 6v.
Old 07-14-2016, 04:27 PM   #11
Joe Immler
I installed an Airtex E-8902 pump on my Ford. 6 volt. I installed it near the fuel tank with an On/Off switch under the dash. They are available at NAPA,Advance Auto Parts and other parts stores. About $45.00. Has been on the car for 3 years no problems. I use it to prime if the car has been sitting for awhile such as winter and to over come vapor lock.I believe it should not be used continuously with the mechanical pump. I say this in case you want this to run full time.
Joe Immler is offline   Reply With Quote
Old 07-14-2016, 04:37 PM   #12
weemark
It runs on 6v or 12v.
Old 07-14-2016, 04:58 PM   #13
JSeery
JSeery's Avatar
That's interesting didn't see anything about that on the Summit site. That would be nice.
Old 07-14-2016, 05:18 PM   #14
CarlG
CarlG's Avatar
I've heard that some guys run 12v pumps on 6v and then don't have to use a regulator. Haven't tried it myself, but sounds like it might just work.
Alaskan A's
Old 07-15-2016, 08:38 AM   #15
John cruzin 40
Thank you all for your input realy help full
Old 07-15-2016, 08:42 AM   #16
John cruzin 40
I decided on airtex 8902 6v thanks again
Old 07-15-2016, 08:55 AM   #17
flathead48
Amazon sells airtex.
flathead48 is offline   Reply With Quote
Old 07-15-2016, 09:18 AM   #18
Ken/Alabama
Ken/Alabama's Avatar
Got mine here. http://www.fifthaveinternetgarage.com/
Old 10-28-2016, 09:13 PM   #19
WQ59B
Got the Airtex 8902 for my 59AB, to replace an ancient Bendix.
Seems to be overpowering the Ford 94; flip the toggle and it keeps on pumping. Carb is rebuilt & rechecked- all OK.
Airtex says the 8902 runs at 3-3.5 PSI, and the FH prefers 2-2.5 PSI. Airtex recommended I use a regulator.
Anyone have a suggestion for a specific regulator?
WQ59B is offline   Reply With Quote
Old 10-29-2016, 12:52 PM   #20
slowforty
slowforty's Avatar
Rock Auto has the best prices. I always like to be cost effective. [Cheap]
slowforty is offline   Reply With Quote
