Old 05-24-2021, 12:15 PM   #1
sphooch
sphooch's Avatar
Default 31 brakes
Hi guys, maybe a little help here. I'm gonna adjust the brakes on my 31 Roadster for the 1st time. should i just follow the Les Andrews guide lines or would you guys have some tips for me.. the car sits on a back yard buddy lift as of right now. do i jack it up , and put 4 stand under the axels or do i do 1 wheel at a time?? thanks and every one have a Great Memorial Day Weekend ...The Hooch
sphooch is offline   Reply With Quote
Old 05-24-2021, 01:09 PM   #2
nkaminar
nkaminar's Avatar
Default Re: 31 brakes
Follow the Ford instructions. Do not change the rod lengths. For each wheel, turn in the adjuster until the wheel starts to drag then out 2 clicks. Then go for a test drive. If the car pulls to one side, turn out one click on that side and test again.
Drive to town and back and then measure the brake drum temperatures with an IR thermometer. Side to side should be within 15 degrees but front to back can be more depending on if the rear brakes are working harder as Ford designed them to do.
Old 05-24-2021, 10:04 PM   #3
700rpm
700rpm's Avatar
This is the correct answer.
Ray Horton, Portland, OR
Old 05-25-2021, 10:16 AM   #4
Big hammer
Whats a backyard buddy? I've adjusted on a level concrete drive way ! A click or two tighter then go for a drive, Enjoy!
get a bigger hammer tap done
Old 05-25-2021, 10:46 AM   #5
DBrer
I do as everyone else suggested. I check the temp on all four wheels after driving a little.
DBrer is offline   Reply With Quote
Old 05-25-2021, 12:35 PM   #6
burner31
burner31's Avatar
Do you have the anti rattle springs on the rear?
If so could you post a pic, I'm having some trouble getting mine to hook-up right.
I'm putting all new brake rods on
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 05-25-2021, 01:52 PM   #7
sphooch
sphooch's Avatar
a back yard buddy is an American made 4 post lift
Old 05-29-2021, 06:05 PM   #8
jayvee34
jayvee34's Avatar
I have had mine for over 28 years, and have never had a single problem,
quality made, and most of all, probably the safest lift on the market.
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 05-30-2021, 06:50 AM   #9
Conaway2
Conaway2's Avatar
I follow the brake adjustment instructions in the Ford Service Bulletins - p.202, I believe. Simple and no block of wood needed.
Conaway2 is offline   Reply With Quote
