Old 06-20-2015, 04:38 PM   #1
Bill in Al
Bill in Al's Avatar
Default four row radiator for 1930?
Are there any 4 row radiators available for '30-1 cars?
Bill in Al is offline   Reply With Quote
Old 06-20-2015, 05:43 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: four row radiator for 1930?
Berg's, Walker, Brassworks could probably make one for you. Also contact Bratton's or Snyders and ask.
A good old time radiator shop could probably put a 4 row core in yours.
Why??
Paul in CT
Old 06-20-2015, 05:53 PM   #3
d.
4 row is typically for a AA truck and the radiator shell is deeper to accommodate the extra depth. A common Model A passenger car or pickup should cool just fine with the standard 3 row core.
If 3 row core ain't getting it done, your issue is probably a clogged block or restricted tubes in the existing 3 row radiator core.
This might call for removing the upper and lower tanks and rodding the tubes.
A can of radiator flush won't do the trick.
d. is offline   Reply With Quote
Old 06-20-2015, 06:04 PM   #4
Bill in Al
Bill in Al's Avatar
Just looking for something to keep my tudor with A/C and OD cool when touring at speed in the southern states including Texas. I'm considering a Berg's 3 tube but wondering about 4 tubes that might fit if any are available.
Old 06-20-2015, 06:54 PM   #5
Greg Jones
Greg Jones's Avatar
Talk to Steve Becker at Bert's Model A. If I am not mistaken their recored heavy duty radiators are 4 rows. Reasonably priced by comparison.
Greg Jones is offline   Reply With Quote
Old 06-20-2015, 10:15 PM   #6
MAG
MAG's Avatar
I have had several 30/31 radiators re-cored to 4 row 10 fins per inch. I have one in my 30 Town Sedan equipped with AC and have no overheating problems. And there is no problem with the fit inside the shell. However, there might be some 30/31 radiators equipped with tanks that will not allow the 4th row.
I have tried to have 28/29 radiators re-cored to 4 row but so far none of them have had tanks that would carry the extra row.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 06-21-2015, 12:18 AM   #7
Jordan
Jordan's Avatar
If you want the best cooling capacity, get a VT modern core. They cool significantly better than the flat fin cores. They aren't right, but most people won't know. I have a 3 row VT core in my town sedan with AC, Overdrive & hopped up motor. It runs 175* in the middle of summer pulling a trailer. You won't regret the modern core.
Cowtown A's
Jordan is offline   Reply With Quote
Old 06-21-2015, 07:25 PM   #8
Bill in Al
Bill in Al's Avatar
Jordan,what is a VT modern core? I haven't found a definition for that. My car is for sure a driver.
Old 06-21-2015, 07:32 PM   #9
whirnot
whirnot's Avatar
I have a 29 with a 4 core from Berts. no issues with fit.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 06-22-2015, 01:42 PM   #10
Bill in Al
Bill in Al's Avatar
Thanks all.
