05-22-2022, 11:20 AM | #1 |
ARP main bearing bolts
Has anyone had any trouble using these lately? I have in the past but the ones i just got apart from being 1/4 inch too long( no biggie) the threaded part bottoms out in the block way before contacting the washer. They are 1/2-13 x3. Im not keen on removing threads from the block in order to get the bolt to seat. Btw its a 42-48 block. Thanks
05-22-2022, 09:31 PM | #2 |
Re: ARP main bearing bolts
Why do you think you need ARP bolts there instead of the stock studs?
05-22-2022, 10:05 PM | #3 |
Stock studs will work up to horsepower levels you would have to mortgage your house to afford..
05-23-2022, 10:02 AM | #4 |
Thanks for the opinions but they dont answer the question
05-23-2022, 10:21 AM | #5 |
"Has anyone had any trouble using these lately?"
This is the only question you asked, to that I say no.
05-23-2022, 10:35 AM | #6 |
05-23-2022, 11:01 AM | #7 |
Thanks. Just curious as i have not had issues with them in the past. Your tag line seems applicable here 51 merc
