05-15-2022, 12:26 PM | #1 |
Flat head stalling
My 1949 F1 recently started stalling on my last few road runs. 15-20 miles, stalls and then it will start again.
Runs perfect for a few miles and stalls again. Any suggestions... |
05-15-2022, 12:36 PM | #2 |
Re: Flat head stalling
Does it restart right away. If so, probably fuel filter.
If you have to let it sit for a while, maybe vapor lock or the coil. |
05-15-2022, 01:07 PM | #3 | |
How long do you have to sit before it will start again?
05-15-2022, 01:08 PM | #4 |
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 05-16-2022 at 08:24 PM. Reason: double post |
05-15-2022, 01:08 PM | #5 |
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 05-16-2022 at 08:25 PM. Reason: triple post |
05-16-2022, 03:44 PM | #6 |
Let it sit a home for two days, yesterday it started and ran just fine, again today it started just fine, This stalling started about two weeks ago, I finally got home, next trip I drove twenty miles but did not make it home.... |
05-16-2022, 03:56 PM | #7 |
Condenser
05-22-2022, 02:59 PM | #8 |
Do not rule out debris in the tank. Had a problem with this. Drove me nuts until I drained the tank with a cheese cloth in the funnel in a 5 gallon jug. Start it up and when it stalls around your property, take the line off the pump and blow back. Quick check.
05-22-2022, 03:40 PM | #9 |
Check that the tank cap is vented ,and take a (as said )spare coil and swap it out
05-22-2022, 06:41 PM | #10 |
+1 on coil as possible culprit
No job’s done ‘til it’s all done |
06-04-2022, 10:12 AM | #11 |
Agree with condenser heating up and failing or clogged fuel filter. Electronics can work fine cold and fail when hot, so if it takes a cool down period to start again, then suspect condenser etc,
Do you have a Pertronix Ignitor? |
07-02-2022, 10:58 AM | #12 |
Another unsolved mystery- they never follow thru with the actual problem, but are great at hollering HELP before even looking at the basics!
07-02-2022, 12:05 PM | #13 |
