Old 11-07-2020, 09:44 AM   #1
kimlinh
Default Waterless coolant
Does anyone use Evans (or any other) waterless coolant. Is it any good for a model A? How well does it work? I'm interested because of the corrosion protection it might give to the model A cooling system.
kimlinh is offline   Reply With Quote
Old 11-07-2020, 09:55 AM   #2
Gary WA
Gary WA's Avatar
Default Re: Waterless coolant
I have used similar products! The best over the years I use NAPA 1300 Rust Inhibitor,with Distilled water!!
www.whidbeymodelaclub.com
Old 11-07-2020, 10:13 AM   #3
eagle
eagle's Avatar
Some people use it because it has a higher boiling point than antifreeze. I don't know what advantage it would be unless your cooling system is marginal.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 11-08-2020, 02:58 AM   #4
Chris Haynes
Chris Haynes's Avatar
I use it. No water = no rust. I do have a pressurized, closed cooling system.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 11-08-2020, 05:13 AM   #5
McMimmcs
McMimmcs's Avatar
Do you add water pump lubricant ?
McMimmcs is offline   Reply With Quote
Old 11-08-2020, 03:31 PM   #6
Chris Haynes
No. I use a leakless pump. No lubrication necessary as coolant never touches the bearings.
1921 Runabout
1930 Tudor
Early 1930 AA
