11-03-2020, 06:38 PM | #1 |
Headlight Seal
anybody got any pictures of proper placement of headlight seals for a 28 A
11-03-2020, 07:32 PM | #2 |
Re: Headlight Seal
cork gasket pushes into channel in reflector
www.whidbeymodelaclub.com |
11-03-2020, 08:31 PM | #3 |
Re: Headlight Seal
Thanks
11-03-2020, 09:18 PM | #4 |
Re: Headlight Seal
Some 3M spray adhesive helped hold them in place for me.
Building a '29 Speedster, the hard way... |
11-06-2020, 11:49 PM | #5 |
Re: Headlight Seal
The split goes at the bottom so moisture can drain out.
11-09-2020, 10:54 PM | #6 |
Re: Headlight Seal
Typical fit for most reproduction parts. |
11-10-2020, 08:01 AM | #7 |
Re: Headlight Seal
Man, ...you went about it the hard way!! Since you are in to the wood scene, just clamp both pieces in-between two pieces of wood and use some clamps to compress the cork. After 15 minutes or so, when you can remove it the cork will remain compressed for more than enough time for you to insert it in the channel.
11-10-2020, 11:08 AM | #8 | |
Re: Headlight Seal
11-10-2020, 11:17 AM | #9 |
Re: Headlight Seal
