Old 07-17-2020, 10:25 AM   #1
34fordy
34fordy's Avatar
Default Axle taper degree
Do all 32-53 Ford rear axles have the same degree of taper into the hub?
If so, what is the degree?
34fordy is offline   Reply With Quote
Old 07-17-2020, 10:51 AM   #2
jetmek
Default Re: Axle taper degree
No only thru 48. WAG 7 degrees?
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 07-17-2020, 11:36 AM   #3
V8COOPMAN
V8COOPMAN's Avatar
True scoop....7 degrees! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-17-2020, 11:40 AM   #4
34fordy
34fordy's Avatar
Thanks for the info!
Old 07-19-2020, 04:06 PM   #5
Yoyodyne
Yoyodyne's Avatar
Is that from a Ford print or some other source? Some other things on Fords are 1.5 inches per foot, which is really close to 7° when you try to measure it. (I've stumbled over this previously, haven't got to the axles yet.)
Yoyodyne is offline   Reply With Quote
