05-26-2014, 01:16 PM | #1 |
Rust Removal
I recently read a thread pertaining to rust removal with molasses, NOT the one started by wrndln. In the thread I read some had a ratio - molasses to water and indicated the type of molasses, wet or dry. I have used the search to find this article to no avail. Can someone help?
05-26-2014, 01:24 PM | #2 |
Re: Rust Removal
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
05-26-2014, 01:41 PM | #3 |
Re: Rust Removal
Thanks to mshmodela but that was not post I was looking for.
05-26-2014, 09:29 PM | #4 |
Re: Rust Removal
I just filled a wash tub with water and poured the try molasses in. Have no idea how much maybe 10-15 lbs. It will not dissolve completely(at least mine didn't)> stirred it with a shovel put the parts in covered it with plywood placed in the sun. It gets a foam on top and I stirred it a couple of times. About two weeks later I had rust free parts. Now that it's getting warmer I'm gonna do some heads and two blocks. May go to a feed store and get some liquid and see how that works. May mix with the water better. Any left over put it on the pancakes.
Sewall Tyler |
05-27-2014, 09:31 AM | #5 | |
Re: Rust Removal
Talked about our use of molasses to remove rust. 9 parts water to 1 part molasses is what we used and it worked great. We used wet molasses that we got from a restaurant supply company. It came in 5 gallon pails. Hope this helps. |
05-27-2014, 07:31 PM | #6 | |
Re: Rust Removal
05-27-2014, 09:07 PM | #7 |
Re: Rust Removal
DUNN1929 - That is the info I wanted to see 9 to 1 and also wet molasses. Now I have to find a place to get some. Maybe I'll just buy some ( 1 qt or 1 gal )at the grocery store and try it myself on some small parts.
Thanks again DUNN1929 |
05-27-2014, 09:23 PM | #8 |
Re: Rust Removal
How about bead blasting and a bead blast cabinet?... I couldn't do without mine! If you're working on them it is a must have.
