Old 08-24-2018, 07:39 PM   #1
arkusvt
Default 8ba dizzy
crt performance offers a drop in, no additional box electronic dizzy for the 8ba complete with both mechanical and vacuum advance, 3 wire hook-up, for $160.00. seems almost too good to be true even chinese made, which i'm sure it is. the company feed back is excellent. anyone had any experience with these? thanks for the input!
arkusvt is offline   Reply With Quote
Old 08-24-2018, 09:07 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 8ba dizzy
Until someone installs one and determines if it's timing curve is truly suitable for the flathead, there's no way to know if they are any good.
Old 08-25-2018, 02:59 PM   #3
supereal
supereal's Avatar
At our shop, over the years, we have seen problems with electronic ignition conversions. Old cars tend to have poor system voltage control which affects stability of the units. The original Ford distributor is practically "bullet proof". Unless you are using the engine for racing, the best is still the stock unit in good shape and properly adjusted.
supereal is offline   Reply With Quote
Old 08-26-2018, 09:17 AM   #4
Frank Miller
Frank Miller's Avatar
So far I've had good luck with a pertronix in a 49 6volt pos grnd and solid core wires. I went to electronic because a new echlin condenser failed on me after about 500 miles. I figure if I'm going unreliable I'd go electronic. I do carry an extra distributor with me just in case.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 08-26-2018, 11:32 AM   #5
flatjack9
flatjack9's Avatar
Much easier to replace a condenser than a distributor.
Old 08-26-2018, 11:51 AM   #6
tubman
tubman's Avatar
That's why I like external condensers!
tubman is online now   Reply With Quote
