07-17-2021, 02:01 PM | #1 |
1933 transmission "gear" oil
It has been a while since I purchased Transmission gear oil. What is available now. Remember that sae 900 crap that was like refuse from a burger pit?
07-17-2021, 02:25 PM | #2 |
Re: 1933 transmission "gear" oil
Sta-lube SAE 140 . GL4
07-17-2021, 02:33 PM | #3 |
Yep, that’s what I use.
07-17-2021, 02:49 PM | #4 |
07-17-2021, 03:09 PM | #5 |
Re: 1933 transmission "gear" oil Depends on the transmission. I use ATF in my T5. He CLEARLY states "1933 transmission "gear" oil" in the header....less than 1 inch away from where you question the transmission type! DD |
07-17-2021, 03:13 PM | #6 |
https://www.oreillyauto.com/shop/b/c...w/754ba5cbea99 |
07-17-2021, 03:17 PM | #7 |
07-17-2021, 03:44 PM | #8 |
Hi Everyone. Frank, I hear you can get it at NAPA, but I usually get it delivered.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
07-17-2021, 05:54 PM | #9 |
Thanks guys...with your help I just ordered a gallon.
07-17-2021, 07:07 PM | #10 |
Not to hijack, but is that what you guys use in the rear axles too?
Thank you. Red |
07-17-2021, 07:33 PM | #11 |
yes here
07-17-2021, 07:39 PM | #12 |
I've always used 80W90 GL4 in the trans....would I be better off running 140? Why?
07-17-2021, 11:02 PM | #13 |
07-18-2021, 10:06 AM | #14 |
07-18-2021, 07:46 PM | #15 |
More to do with climate BB .. Im now trying the 85-140 mineral from Penrite its a GL5 but its supposed to be ok. As you know Im sub tropical no freezing here ..
"Came too close to dying to stop living now!" |
07-18-2021, 08:00 PM | #16 |
Oh, ok. I see Shoovel, who lives in Ontario, Canada, shares the same climate as Perth, WA lol
