Old 06-21-2021, 12:09 PM   #1
psimet
psimet's Avatar
Default Horn stopped
Finally got a battery in the car. Horn worked (sickly of course) then stopped after a while. If we hit the horn button the ammeter drops.
Ideas for troubleshooting?
psimet is offline   Reply With Quote
Old 06-21-2021, 12:13 PM   #2
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Default Re: Horn stopped
Back off on the adjusting screw quite a bit so it won’t make noise. Then hold down the horn button and let the horn motor run up for about 30 sec. then adjust it to get a good sound. I’m sure it needs lube also. See if this helps.
Jacksonlll is offline   Reply With Quote
Old 06-21-2021, 10:46 PM   #3
PalAl
PalAl's Avatar
These may be helpful
PalAl is offline   Reply With Quote
Old 06-21-2021, 11:48 PM   #4
psimet
psimet's Avatar
This did it. I had lubed it but apparently it was too much. I backed it off and spun it. Kept getting faster each time. Couldn’t keep it running for 30 seconds though without the horn button getting fairly warm.
Old 06-21-2021, 11:49 PM   #5
psimet
psimet's Avatar
Sweet! Thank you. I’ll dig through them.
