05-01-2016, 12:46 PM | #1 |
1935 horn wiring problems
Ok I am trying to get two new horns wired up on a 1935 restoration. The wiring harness has 6V to ground on the two yellow wires on each side. On the Blue Yellow wire I get a short to ground when the horn button is depressed and a break when it is released on both sides.
This Seems correct to me at this point, so this is where the fun begins. I have two new 6v horns from Dennis Carpenter or some other vender. I have taken them apart to see which terminal is ground and which goes through the electro magnet. If I check both the terminals they short to each other and to ground (not sure if that is correct). When I hook up the right horn it works correctly (it works with the horn button) but I get 6v to ground on both wires on the left. and can't hook the other horn up. Any thoughts anyone. Could the problem be in the horns themselves? thanks |
05-01-2016, 12:56 PM | #2 |
Re: 1935 horn wiring problems
Well, I'm confused if that helps. The Yellow wire should be power from the battery via the starter switch. And the Blue/Yellow wire is the ground via the horn button. Sounds like they are working OK. And also, one horn works, correct? So have you tried only connecting the other horn and see if it works independently?
05-01-2016, 01:16 PM | #3 |
Yellow does have 6v on it.
if I connect the second horn it goes on with pressing the horn button |
05-01-2016, 02:56 PM | #4 |
So each horn works ok seperatly but will not work together?
05-01-2016, 05:05 PM | #5 |
correct
05-01-2016, 05:13 PM | #6 |
05-01-2016, 05:30 PM | #7 |
if the positive of the battery is ground, then you may have to reverse your wiring
05-01-2016, 07:19 PM | #8 |
ssrcobra, Neither horn terminal should short to ground. They should be isolated from the horn body
05-01-2016, 11:09 PM | #9 |
yellow to starter switch....blue yellow to bottom of steering column for horn button??....Mike
http://www.vanpeltsales.com/FH_web/F...wiring1935.jpg |
05-01-2016, 11:16 PM | #10 | |
05-02-2016, 09:14 AM | #11 |
I think if he bought them from Carpenter, these are new repro horns and they are grounded through the frame and you have to use a horn relay with them. the horn switch will run the relay and the relay then powers the horns. I had a pair of the repros on my 35 and thats the only way to make them work. You can't wire them up like originals.
05-02-2016, 04:27 PM | #12 |
I would like to know, is the yellow wire from the starter switch to the front harness to the horns a separate wire all by itself flopping around loose,
or is it included in a harness? |
05-02-2016, 04:39 PM | #13 |
it is in a harness,
the harness is correct and working correctly both yellow wires show 6v across them to ground both blue and yellow wire give connectivity to ground only when the horn button is depressed Carolina-bob hit the head on the nail or at least kind of, I think it is the after market horn or they where grounded to frame not needing the horn but to give them connectivity. I hooked up my originals (which sound so much better) with them laying on the floor of the garage. everything is working. So, I plan to you the originals and just make sure they are isolated from the frame. thanks you all for any help |
05-02-2016, 04:47 PM | #14 |
Good to hear you figured it out!
05-02-2016, 11:19 PM | #15 |
for what its worth and per 1941 and later .... this is stock:
Circuit: Wire Color: Wire Gauge: Starter Relay to Horn Relay; Yellow with Green 10 Horn Relay to Horn Button; Blue with Yellow 14 Horn Relay to Horns. Yellow with Green 14 (also found as Yellow with Black) |
