Old 02-21-2012, 10:15 AM   #161
56 ford custom
Default Re: 1960 f100 with 292 yblock which auto trans to use?
Haha! Ok well I will do that hopefully today then. I now needto find a radiator shop near by.
56 ford custom is offline   Reply With Quote
Old 02-23-2012, 04:21 AM   #162
all american boy
all american boy's Avatar
'56 Custom
you successfully 'broke loose' the two steel lines
'of' the truck style transmission cooler?
can you post a pic of passenger side of trans
main case now?
have you solved mystery of what the remaining line
on the passenger side is?
bob
'Has racing made you a millionare?'
'Yes it has.Before I was a multi-millionaire.'-Quote
all american boy is offline   Reply With Quote
Old 02-23-2012, 10:27 AM   #163
56 ford custom
Well I got the bellhousing off now I am still cleaning everything. Its pretty bad haha. The big long hose is going to the water pump for "Pressure"
Old 02-23-2012, 01:17 PM   #164
all american boy
custom
remember to post picture of
passenger side of trans.
repeat: let the Gunk do the work.
spray it on real good
maybe 2 or 3 coats.
go do something for 20-30 min.
regular hose ought to do it.
Have A Nice Day!
Old 02-23-2012, 01:46 PM   #165
56 ford custom
I let it sit for quite some time last night....its soo damn gunked up. I also used alittle brush but it just piles up on the brush. Or I need a better brush?
Old 02-23-2012, 01:58 PM   #166
all american boy
custom
1 if you're using a brush at all your doing
something wrong.
Gunk Original Formula.
it's just plain thin liquid spray like WD 40.
soak grunge on trans real good.
let sit awhile.
should come right off.
Have A Nice Day!
Old 02-23-2012, 02:19 PM   #167
56 ford custom
This said original but its a foam
Old 02-23-2012, 02:52 PM   #168
all american boy
custom
i'm looking at can i bought at walmart.
blue & orange.
Gunk
'engine brite'
Engine Degreaser
Original
no i haven't sprayed mine yet.
i do sort of remember foam thing.
then it turns to liquid.
can you take that picture please?
so we can move on to that other fitting?
we are trying to help other little Fordomatic
owners here at the same time.
aren't we?
Have A Nice Day!
Old 02-23-2012, 03:20 PM   #169
56 ford custom
Well the second hose goes to the water pump for flow and pressure. I will post pics after work.
Old 02-23-2012, 03:30 PM   #170
all american boy
custom
i meant the
passenger side
main transmission case
showing:
two fittings where the cooler hooks up
and steel 'mystery' line
Have A Nice Day!
Old 02-23-2012, 03:40 PM   #171
56 ford custom
Well I was told it was a breather line. Its an open line that points back towards the rear of the case.
Old 03-06-2012, 12:48 PM   #172
56 ford custom
Well I have been cleaning the front section of the frame and the rest of the trans. Im still trying to find some literature and shop pictures of this trans and to prove to myself how the inlet hose hooks up to the water pump or if it has a t that splits it to the heater. Somebody here must have the same set up or have some pics.
Old 03-07-2012, 02:38 AM   #173
all american boy
56 custom
some suggestions:
1 start a new post with that specific question
including as many pictures as you can.
2 get a manual.
http://www.forelpublishing.com/estor...?idproduct=343
there's an old timer sitting in Virginia waiting for
your $25 plus a couple of bucks shipping.
that link is for '64 manual, make sure you get a '60 one.
Have A Nice Day!
Old 03-07-2012, 12:16 PM   #174
56 ford custom
Well I am being told that this isnt the stock trans so I dont think that would do me any good.
Old 03-08-2012, 01:28 PM   #175
56 ford custom
After talking with multiple people on different forums and on phone... This trans is correct for my truck. Also the "cooler" isnt a cooler its a "heat exchanger" if anyone here has the same set up please post pictures of how its all put together or a diagram from a manual. Thank you
Old 04-30-2013, 09:58 AM   #176
mchawk
If anyone is still interested here is a diagram.
I have this same setup on my two 67 F250 camper specials with 352's, but the water lines come out of both sides of the block, diagram only shows one side.
The T- fitting in the lower radiator hose on both of mine rusted out and I had some made out of exhuast pipe.
I have since junked the heat exchangers on both because of leaks and plumbed to the lower radiator tank and then to a tranny cooler in front of the radiator.
mchawk is offline   Reply With Quote
Old 10-18-2014, 03:26 PM   #177
56 ford custom
Good afternoon fellas. Well I had put a stop on the transmission cooler situation for some time now and fully restored the chassis. Now im ready to figure out this issue. Any help would be great! Thanks.
Old 10-19-2014, 10:00 AM   #178
jimc9990
jimc9990's Avatar
Since you are undecided still and ask, here it is.
Do your self a favor and do as " rick55" suggested on 2-20-2012 post # 155 and forget the old "heat exchanger / cooler " . Put a good one in front of the radiator. I have been doing it that way for 20+ years and have never had any problems with my tranys when it is cold . I'v done it with both Ford and Chevy transmissions , no problems. Why do you think nobody is using the old "heat exchanger" ? They were crap and that's probably the reason Ford quit using them.
You ask and that's my humble opinion , have a good day.
JIM
jimc9990 is offline   Reply With Quote
Old 10-19-2014, 04:23 PM   #179
56 ford custom
I have decided to stay with the heat exchanger. I just need to connect it all correctly.
Old 10-22-2014, 05:52 PM   #180
CarlG
CarlG's Avatar
JIM.
On my '71 F100 with a C6, I made a cooler out of parts from an old freezer, mounted it in front of the radiator. 30 years later still doing it's job
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
