06-27-2021, 03:28 PM | #101 |
Re: New baby 1953 Merc
rotorwrench,,
Thanks for the update. Now at least I know my transmission came form the Warner Gear Division plant. One more piece of the puzzle. If I can find a good enough one, I can make a decal that will go over the original plate. That, with a couple of coats of clear, and it should look like it just came from the factory. I know the tag place you are referring to, they did my vin tag, and it looks new. |
06-27-2021, 04:40 PM | #102 | |
I also have a '53 Ford small case Ford-O-Matic transmission on the garage floor that I could take a digital photo of if you think it would help, but I don't think there's much difference. Xmission-tag.pdf |
06-27-2021, 04:57 PM | #103 | |
Oil bath air cleaners gone now? I am still using the original oil-bath air cleaners on both my '55 sedan 272, 2-bbl and my '55 Courier 223, single bbl. Cleaning them is a drag even though they are never that bad, but ya gotta go thru the motions. They both look and function well. Oil filter cartridges weren't meant to be re-used anyway. I kept my old cannister and Purolator P48 oil filter cartridges up until about 25 years ago, but if you ask me, I never had any problems with the old cannister type. You may save a few minutes with the spin-on type filter, but I never saw it as reason to gripe about the old style filter. |
06-27-2021, 05:34 PM | #104 |
Here is a photo of the '53 small-case Ford-O-Matic tag. This was factory installed behind a 215 I-block 6-cyl engine. The air-cooled torque converter was one of the last of the old design that used a flat gasket between the flywheel plate and converter housing. The newer design included a large o-ring gasket instead of the round flat gasket and the converter housing had a small chamfer cutout from the inner surface to accept the o-ring.
53-Fordo-tag1.JPG |
06-27-2021, 07:23 PM | #105 | |
Based on the post from rotowrench, I am wondering what plant it was built in: The serial will tell you a little bit. The first digits before the hyphen designate the plant code. A "2", "6", or "10" prefix indicates Cincinnati plant by FoMoCo. A"1", "5", or "9" prefix designates Warner Gear Division. The linear serial number started at 10001 followed by 10002 and so on. This information comes from the 1953 dated revision of the Merc-O-Matic transmission repair and adjustment manual. I note that mine had 6 digests after the first digit and hyphen, wonder if that means anything? Thanks again for the PDF/Xerox of the tag. Last edited by Merc Cruzer; 07-23-2021 at 09:44 AM. |
06-28-2021, 01:11 AM | #106 | |
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
06-28-2021, 01:15 AM | #107 | |
A little more dust has to settle before attempting to have a repro done.
06-28-2021, 08:42 AM | #108 |
It is 105 pages long. Is there a certain section or do you want the entire book? You are right, the one shown in the book is Black and White. The one in Red is the best one so far.
06-28-2021, 10:17 AM | #109 |
No, all I would like to see is the ID page rotorwrench referred to as to how to determine CODE BREAKDOWN from the 1953 TRANS WSM (and any other year WSM you may have that has the same description).
I need exact text/verbiage.
06-28-2021, 11:24 AM | #110 |
I'll see if I can set up the scanner and get a file for that page.
The FOM for the 215 6-cylinder would not be covered by the Merc-O-Matic manual since it is Ford. It is likely the code for Dearborn since that is listed on the tag but I don't know. Tags can be from anywhere but the transmission could still have been made at a different Ford plant. Looking at post #108 again and I see that that is the same information that is in the manual I have verbatim in photos 2 and 3 at the top. I have that same green manual at the bottom. I don't have a Ford-O-Matic manual. The model information comes from the fourth page in Charely Tranny's Ford transmision identification information for FOM/MOM 3-speeds. It appears to be similar to information I've seen in the old Motors Manuals but it could be FoMoCo I don't know. Here is a link to the access page. https://www.charlietranny.com/FordomaticID.htm Last edited by rotorwrench; 06-28-2021 at 11:42 AM. |
06-28-2021, 12:20 PM | #111 |
Would the numbering system have been the same on both the Fords and Mercurys? The reason I ask, is the serial numbers as described in the book, only had 5 numbers, following the initial digit followed by the hyphen, and mine has 6 numbers.
Or the answer would be, they just made more then they originality thought, therefor the numbers were longer. Hopefully these pictures (from page 45) are a little easier to read. I have started calling local transmission shops to see if i can find a good original. |
06-28-2021, 01:48 PM | #112 |
If they serialized by model number then numbers in the tens of thousands may have covered their bases. If they didn't then they may have needed a lot more prefix numbers to cover their amounts manufactured. There just isn't enough info to know that sort of stuff.
06-28-2021, 03:37 PM | #113 | |
What you have copied is exactly what I need. I will cipher on them.
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 07-23-2021 at 05:57 AM. Reason: TO CORRECT THOUGHT PATTERN AND TEXT |
06-28-2021, 03:45 PM | #114 |
THANX! rotorwrench ...
The ID is not all that difficult if one has the resource material to weed through it. What was posted is what I need hopefully. You had SERVICE INFO, PARTS INFO and the most I wish I had was SERVICE LETTERS. But I believe when all the dust settles, his will be a 1P-7003-N BW assembled. And I can't believe no one is either restoring or reproducing these tags. Most everything else is available.
06-28-2021, 05:14 PM | #115 |
In reality, I am only a digital photograph away from being able to reproduce them. There so many artisans on Etsy that can do just about anything, once you present it to them. Reverse engineering the original process, should not be an issue with today technology.
06-28-2021, 10:38 PM | #116 | |
The model no of the '53 Ford-O-Matic is 1P-7003-C. The serial number is 4-89996. Note here that the first digit (4) of the serial# is painted on in red paint along with the red background. But they may have done it differently for Merc transmissions. I assume it was made at the Dearborn plant, as indicated at the bottom of the nameplate. However, if you looked at the PDF of the '55 Ford-O-Matic, it shows Muncie, Indiana and has a longer serial number with 3 digits before the hyphen. |
06-28-2021, 11:27 PM | #117 |
I have FOM in my 1956 F100 The tag was all there and in good condition when I took it in for the rebuild. Unfortunately, most of the red paint came off during the rebuild. If someone make a good decal, I would sure buy one. I know you don't see it unless you are under the vehicle, but I would still like to have it restored.
06-29-2021, 02:38 AM | #118 | |
06-29-2021, 08:14 AM | #119 |
ADDITIONAL INFO FORD and the Warner Gear Division of Borg-Warner signed a contract in 1948 which entered B-W into a supply agreement wherein they would build half of FORD's transmissions for five years (NOTE: That would be 1951-1954 Model Years), with the other half either being built by FORD or by a different supplier. Because of this agreement, Ford licensed the design themselves and broke ground immediately on an assembly plant to build the remaining transmissions.
The new plant, called Fairfax Transmission Plant (CIN OH), was dedicated in 1950. SOURCE - https://en.wikipedia.org/wiki/Cruise-O-Matic#MX/FX BW Plant – Decatur, IL
06-29-2021, 08:38 AM | #120 | |
I will probably have to do the same thing for trucks and 6 cylinder cars too, just to be sure. Last edited by Merc Cruzer; 06-29-2021 at 10:11 AM. |
