Old 08-31-2018, 03:56 PM   #1
nosoup4u
Default Car goes too fast!
Okay, this may sound goofy but here is what I am doing. I am making something like a model T speedster with as many parts as possible from old John Deeres. The front and rear axles are model A ford. There is a precedent for this as Deere used a model A transmission and steering column in one of their tractors.
The engine I am using is a flat head two cylinder vertical capable of only about 14 horse at 1500 rpm. Anyway I got the steering, clutch and accelerator and a makeshift seat hooked up the other day and drove it out of the shop. It is scary fast! I was hoping to be able to put around tractor shows in low gear at maybe 5 -10 mph but there is no way to hold this thing down that slow.
I bought the rear axle from a model A restorer years ago and I have no idea what it came off of so I have to assume it has the standard 3.78 ratio.
Other than trying to find a 4.33 or 4.55 ring gear is there anything else I can do to slow it down?
nosoup4u is offline   Reply With Quote
Old 08-31-2018, 04:06 PM   #2
aermotor
Default Re: Car goes too fast!
Pull one spark plug wire.
John
aermotor is offline   Reply With Quote
Old 08-31-2018, 04:42 PM   #3
denniskliesen
denniskliesen's Avatar
Find AA rear axle.
denniskliesen is offline   Reply With Quote
Old 08-31-2018, 04:44 PM   #4
Dave in MN
Dave in MN's Avatar
Originally Posted by denniskliesen View Post
Find AA rear axle.
Yup! With Worm drive.
Dave in MN is offline   Reply With Quote
Old 08-31-2018, 05:07 PM   #5
SeaSlugs
SeaSlugs's Avatar
or a 4 speed AA trans. 1st is granny low.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 08-31-2018, 05:10 PM   #6
nosoup4u
I wouldn't be opposed to putting in an entirely new rear axle since the brakes on the present one are going to need virtually every part replaced. Doing a little googling it looks like these rear ends are from 5.4 to 7. something ratios, which would be better.
Questions:
1. Is the drive shaft assembly similar to a car, will they bolt to a regular 3 speed.
2. Will model A passenger wheels bolt on?
Old 08-31-2018, 05:23 PM   #7
Bob C
Use a AA truck 4-speed transmission.
Bob
Old 08-31-2018, 05:30 PM   #8
noboD
Or two transmissions.
noboD is offline   Reply With Quote
Old 08-31-2018, 05:31 PM   #9
Bob C
1. Is the drive shaft assembly similar to a car,yes will they bolt to a regular 3 speed.Yes but he u-joint can be hard to find
2. Will model A passenger wheels bolt on?No.[/QUOTE]
This link may give you some ideas. https://www.fordbarn.com/forum/showt...ght=doodle+bug
Old 08-31-2018, 05:51 PM   #10
nosoup4u
How difficult would it be to replace the three speed with a four speed?
Old 08-31-2018, 06:46 PM   #11
redmodelt
redmodelt's Avatar
Very interesting, don't know of any John Deere that used any Model A parts.
Old 08-31-2018, 08:13 PM   #12
nosoup4u
The model Y built in 1936. Only 26 built.
Old 08-31-2018, 09:35 PM   #13
SeaSlugs
SeaSlugs's Avatar
Bolts to the same engine, I know of several standard model A pickups that have a 4 speed in them, im not sure if they had to shorten the rear end any or not - i dont think they did...
it did just bolt in though.
Old 08-31-2018, 09:35 PM   #14
40 Deluxe
Do you have any references for the Model Y? I'd like to read more about it. Thanks!
Old 08-31-2018, 09:37 PM   #15
denniskliesen
What's the torque on that engine? For a 2 cylinder, they had a lot of grunt.
Old 08-31-2018, 09:45 PM   #16
nosoup4u
https://greenmagazine.com/small-mich...pment-model-y/
Old 08-31-2018, 09:50 PM   #17
nosoup4u
I don't know what the torque is. It's 3.5 x 4 bore and stroke two cylinder. Runs to 1850 rpm. I was afraid it wouldn't have enough power to pull the thing and it's so fast it's scary for what I want to do with it.
Old 08-31-2018, 10:08 PM   #18
40 Deluxe
Thank you for the reference! Learned something new today. With only 40-some made and then "un-made" within a couple of years, it's small wonder that even most Deere collectors aren't familiar with it.
