02-24-2018, 11:46 AM | #61 |
Re: Power Steering Make Up 56 Wagon
02-24-2018, 06:50 PM | #62 | |
I thought it would be more of a common problem with just one fastener at the bottom of the rail. Guess you just lucked out...
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
02-24-2018, 07:59 PM | #63 |
Sure, I feel very privileged. (haha)
It might have something to do with the car having a replacement oem frame. . Last edited by dmsfrr; 02-24-2018 at 08:09 PM. |
02-24-2018, 08:14 PM | #64 | |
Forgot that little factoid...
02-25-2018, 03:56 PM | #65 |
02-25-2018, 04:52 PM | #66 |
I don't know if it is allowed to mention them here but if you want I can PM you a vendor.
02-25-2018, 09:04 PM | #67 |
02-26-2018, 05:11 AM | #68 |
02-26-2018, 09:45 AM | #69 |
KULTULZ,
Received the PM with the sites, thank you. I installed the factory PS on my 53 Merc last year and could not for the life of me find the crush nuts. I had to improvise by taking a fender "J nut" and cutting of the bottom piece and then soldering it onto a coat hanger and then threading it threw a bolt hole in the frame and and down to the hole in the frame where the crush nut would go. Then I mounted the bracket with the other two bolts and then very carefully threaded the bolt up through the hole into the nut. It works fine but I always wanted to have the correct insert in the event I do it again. When I was looking all I found were Sert's and they are round, and from the feedback I got, they didn't hold all that well anyway. Thanks again. Merc Cruzer |
02-26-2018, 02:13 PM | #70 | |
If you ever need one again and are hard to find, just GOOGLE 375474-S8. Here is a source for all kinds of retainers- https://www.amkproducts.com/Catalog_PDF/56-73.pdf
02-27-2018, 12:29 AM | #71 |
Chevy Dealers have them in stock for Corvettes.
03-09-2018, 08:15 PM | #72 |
I tried to find the nut locally, so I stopped in the local Chevy dealer, parts department, this afternoon and took them a picture of the "crush nut' and it was like living the add from Rock Auto. Bottom line, since I didn't have a Chevy part number, they had no way of looking it up. I tried their body repair department and again no luck....the manager at least knew what it was.
You wouldn't by chance have a part number, or a year of application? Thank you, Merc Cruzer |
03-10-2018, 02:07 AM | #73 |
03-10-2018, 10:36 AM | #74 | |
Thank you for the information. I decided to go with NPD due to ease of ordering and shipping, and they had them in stock for Ford / Mercury application. Merc Cruzer |
03-20-2018, 07:35 PM | #75 |
Finally got them installed...
03-20-2018, 07:40 PM | #76 |
Looks awfully professional...
03-21-2018, 08:31 AM | #77 |
The instructions tell you the nut, bolt and washer "tool" is only good for a couple of installations and they are not kidding. Just one more thing I learned to do that I probably will never do again. "All this knowledge and no where to use it"
03-22-2018, 04:16 AM | #78 |
No, you may be able to help someone else down the line.
