02-27-2019, 09:17 PM | #21 |
Re: Brake Fluid
Teflon tape on the originals does the same thing. Cost = about 2 cents each. It's not rocket science.
02-28-2019, 06:47 PM | #22 |
Re: Brake Fluid
You shouldn't need teflon tape on any brake fittings. If you do you have a problem. Do OE manufacturers use teflon tape? No of course they don't.
Mart. |
02-28-2019, 11:59 PM | #23 |
Re: Brake Fluid
He was just talking about so it won't suck air around the threads while bleeding with a tube.
03-01-2019, 03:03 AM | #24 |
Re: Brake Fluid
Ok good point. I put some red rubber grease around mine when using a vacuum bleeder. I think that helped.
03-02-2019, 08:57 PM | #25 |
Re: Brake Fluid
Just put DOT 5 in a complete rebuild. Beware of brake light switch failure if you use an original switch. I would recommend using a mechanical switch.
03-02-2019, 11:02 PM | #26 |
Re: Brake Fluid
03-03-2019, 09:09 AM | #27 |
Re: Brake Fluid
Please explain to those who would like to know, why DOT 5 causes the failure of brake light switches.
Every failed switch (using DOT 3) that I have cut apart to inspect shows that failure was due to arcing at the contact points causing a non conductive build up of material, thus , no continuity. The contact points are not immersed in any brake fluid. |
03-03-2019, 10:09 AM | #28 |
Re: Brake Fluid
I would much rather have a mechanical switch and never change fluid or have the expense of new wheel and master cylinders. I personally have never had a switch failure, but only read what is stated here on the Barn. With that said, I can change a switch faster than anyone can change fluid or replace all of their brake components. My model A, Mustangs and others have had the same DOT 5 fluid in them for years with no problems. Plenty of moisture and corrosion problems with other cars using DOT 3
03-03-2019, 10:28 AM | #29 |
Re: Brake Fluid
Totally agree with the use of DOT 5 and a mechanical brake light switch.
The mechanical switch, not because of possible failure of a pressure switch but because a mechanical switch will allow the brake lights to activate as soon as the pedal is minutely moved and it does not depend on brake line pressure to activate. How many would like to see their brake lights come on sooner than later??
03-03-2019, 09:56 PM | #30 |
Re: Brake Fluid
"How many would like to see their brake lights come on sooner than later??"
I have a switch to turn mine off when running from rev'noooers. |
