Old 06-08-2021, 09:30 PM   #1
backrodebob
backrodebob's Avatar
Default coil
QUESTION? 12 v system, external 1.5 resistor with 1.5 coil or 3.0 coil pros cons or personal preference? some say 3.0 gets hotter? true or not?
backrodebob is offline   Reply With Quote
Old 06-09-2021, 08:00 AM   #2
51504bat
51504bat's Avatar
Default Re: coil
On my '39 p/u with an 8ba converted to 12 volts I'm using a 012 Bosch Blue internal resister coil. Works great with no issues. Just my experience.
Old 06-09-2021, 12:02 PM   #3
JSeery
JSeery's Avatar
Default Re: coil
The 3.0 ohms coils are easier to install, but there are advantages to a resistor + coil setup. That is why Ford used a resistor with the original 6v coils. The resistor varies the resistance as it heats up, so there is more voltage going to the coil at startup. If you really want to go whole hog, add a later model starter solenoid. This is the arrange Ford used on the later 12v vehicles. The solenoid setup bypasses the resistor for full battery voltage to the coil while the starter switch in engaged. As soon as the switch is released the coil voltage is dropped down by the resistor.
Old 06-10-2021, 07:31 AM   #4
rotorwrench
rotorwrench's Avatar
Default Re: coil
If all is working well, the coil will not increase in temperature all that much and even if it does, the modern coils generally use an epoxy internal insulator instead of tar like the old coils did. When the coil is in operation, the magnetic field is getting broken multiple times per second. They only get hot when the points are closed and the ignition switch is on when the engine isn't running as a general rule. Now if something is wrong inside the coil like a cracked primary winding wire, then the resistance of the primary increases and that can lead to overheating. Eventually the coil will cease to function if the primary is damaged.
