Old 06-06-2021, 11:41 AM   #1
30aadoodlebug
30aadoodlebug's Avatar
Default Black smoke and backfiring in stock 41 Ford
So my parents 41 woodie broke down yesterday. Its a new rebuilt engine with fenton duals and smitty glass packs. Of course there are a few holes in the smittys I patched to try and diagnose the problem while Im waiting for the new ones to come in. Shes still blowing black smoke and running rough. I checked the electrical, and all seems fine. Im leaning towards a clogged jet in the carb.
Any help would be appreciated.
30aadoodlebug is offline   Reply With Quote
Old 06-06-2021, 11:51 AM   #2
alanwoodieman
Default Re: Black smoke and backfiring in stock 41 Ford
power valve bad--carb float set too high--inlet need valve has trash under it. clogged jets in carb would not flood out engine but just the opposite it would lean the engine out
alanwoodieman is offline   Reply With Quote
Old 06-06-2021, 12:12 PM   #3
30aadoodlebug
Right you are Alan! Power valve is toast!!!!
Old 06-06-2021, 12:14 PM   #4
Ronnieroadster
Ronnieroadster's Avatar
Engine is getting way to much gas the is carb leaking to much gas areas to look at as noted in above post.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 06-06-2021, 12:48 PM   #5
jayvee34
jayvee34's Avatar
If it backfired when first started after rebuild the power valve was surely blown.
Black smoke is to much gas,.
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
