05-23-2021, 06:01 PM | #1 |
stromberg elictronic distributor
any info how good is 6volt pos earth for my 3 bolt 37 coupe ?
05-23-2021, 06:46 PM | #2 |
Re: stromberg elictronic distributor
Pre-'49 stock flathead Ford distributors, set up properly, are usually the best ignition to be used on these engines.
If you are stlll high on the "E-Fire", check this thread out : https://www.fordbarn.com/forum/showt...ight=Stromberg. Nuff said! |
05-24-2021, 06:16 AM | #3 |
some guys lovem some hate them havent seen any test data so its still a lottery
05-24-2021, 01:16 PM | #4 |
Considering how the replacement points and condensers are such poor quality off shore junk your lottery chances are much better using the Stromberg dizzy.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
05-25-2021, 01:33 AM | #5 |
Only problem I had was starting on 6volt, the battery had to be fully charged otherwise the starter robbed the dizzy of power. Changed back to helmet and it fires up even if left for a month
05-25-2021, 09:14 PM | #6 |
