Old 02-26-2021, 07:03 PM   #1
theriddler56
Send a message via Yahoo to theriddler56
Default 41-48 distributor
What are the differences between a 21a and a59a distributor? Any info would be appreciated.
theriddler56 is offline   Reply With Quote
Old 02-26-2021, 07:33 PM   #2
35fordtn
35fordtn's Avatar
Default Re: 41-48 distributor
The caps, cap clips, and rotor are the only difference in a 42 21a and a 46-48 59a
35fordtn is offline   Reply With Quote
Old 02-26-2021, 09:19 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
A '41 distributor is a model "11A-" distributor and is the last of the 'diving helmet' dizzies....below!
The "21A-" is a 1942 distributor, commonly called a "Crab Cap" distributor. Note the two snaps to hold "crab" cap in place.
Crab cap and wires below!
The "59A-" is the '46-'48 Ford/Mercury distributor, commonly called a "Rabbit Ears" distributor. Essentially the same distributor as the "21A-" with a different "Rabbit Ears"-looking cap held on with a single bail....below! DD
Click Links Below __
T5 W/TORQUE TUBE
