Old 02-23-2021, 09:48 PM   #1
Habusailor
Habusailor's Avatar
Default Distributer timing fixture
I am looking for a KR Wilson distributer timing device, anyone have one they will part with?
Sent from my SM-T550 using Tapatalk
Habusailor is offline   Reply With Quote
Old 02-24-2021, 08:24 AM   #2
Blindhuckster
Blindhuckster's Avatar
Default Re: Distributer timing fixture
There is one on ebay now. Nate
Blindhuckster is offline   Reply With Quote
Old 02-24-2021, 10:59 AM   #3
petehoovie
petehoovie's Avatar
See > https://www.ebay.com/itm/VINTAGE-K-R...IAAOSwMJNgLBVy
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 02-25-2021, 08:55 AM   #4
Blindhuckster
Here's another one on ebay. Nate
https://www.ebay.com/itm/274695771698?ul_noapp=true
Old 02-25-2021, 11:30 AM   #5
Ken hash
Ken hash's Avatar
I looked at the one on eBay and it looks like it’s missing the adapter plate for either two or three bolt. Distributor.
Ken hash is offline   Reply With Quote
Old 02-25-2021, 01:00 PM   #6
35fordtn
35fordtn's Avatar
The metal box version is far superior to the wooden box version
35fordtn is offline   Reply With Quote
Old 02-25-2021, 03:22 PM   #7
Bill OH
I would suggest that you set the points at .015 - .016” clearance with a feeler gauge and establish TDC on the crank pulley using the hard stop method, which has been outlined in previous posts. With engine at idle you can set the initial timing 4 degrees ahead of TDC and watch the advance of the distributor as you increase the rpm of the engine, the latter you cannot do with the Timing Fixture. You can also add a pig tail about 8” long connected to the condenser coil terminal and terminated in a ball of solder on bare wire, with pig tail being zip tied to the ignition wire loom, being careful that the solder ball does not become grounded. Pigtail is handy to connect a dwell-tach. This is how I got around the Timing Fixture.
Bill OH is offline   Reply With Quote
Old 02-25-2021, 03:26 PM   #8
petehoovie
petehoovie's Avatar
Old 02-26-2021, 01:24 PM   #9
Kurt in NJ
Kurt in NJ's Avatar
The wood box ones won't do later distributors unless it was sent back for updating, it is in the service bulletins about the difference
Thread Tools
Display Modes
