Old 02-05-2021, 12:11 PM   #1
Jeff M
Default Removing 1930 front fenders
I need to remove my front fenders to do a frame repair on my 30 coupe. I already have the hood, rad, engine, radiator apron removed. What’s the procedure to remove them? Do I have to loosen all the body bolts or can I just loosen the front under the cowl that mount them?
Jeff M is offline   Reply With Quote
Old 02-05-2021, 12:33 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Removing 1930 front fenders
Just remove the fasteners that hold the fenders.
Old 02-05-2021, 12:36 PM   #3
fundytides
fundytides's Avatar
I have found it easier if you loosen the fender bracket to frame bolts. Otherwise it's hard to remove the headlight bar to fender brace bolts.
fundytides is offline   Reply With Quote
Old 02-05-2021, 12:37 PM   #4
Jeff M
I already have the headlight bar off, I forgot to mention that.
Old 02-05-2021, 02:40 PM   #5
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
You guys are missing the point where he said he is working on a 1930. Remember the 1930 fender uses a two-piece apron that will require the body to be lifted slightly in the front to get the fender out from underneath the body.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-05-2021, 02:58 PM   #6
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Loosen that front body mount, jack it up a bit, and the fender will slide out. Good luck.
Jacksonlll is offline   Reply With Quote
Old 02-06-2021, 07:28 AM   #7
shew01
shew01's Avatar
Brent, are 1931 fenders mounted under the body the same way?
shew01 is offline   Reply With Quote
Old 02-06-2021, 07:34 AM   #8
Oldbluoval
Oldbluoval's Avatar
Not Brent but....
No Ford changed to the long splash apron that took care of that in 31
Oldbluoval is offline   Reply With Quote
Old 02-06-2021, 10:35 AM   #9
Roger V
Roger V's Avatar
While you need to jack up the body slightly, you should remove the steering column bracket to the gas tank. Doesn't take much to get a gasoline leak.
Roger V is offline   Reply With Quote
Old 02-06-2021, 11:21 AM   #10
gdmn852
gdmn852's Avatar
Hello,also sometimes the fuel line and distributor may need to be loosened. There will be four bolts that will need loosen and removed ,one one each side at front of cowl and 3 on each side near outside of floor boards the body to frame webbing may also need changed it’s about $20. for a roll and has to be cut to fit.
gdmn852 is offline   Reply With Quote
Old 02-06-2021, 12:36 PM   #11
gdmn852
gdmn852's Avatar
Y054CA81F-F943-443E-BBE8-6996E0DC9727.jpgNote distributor ingnition cable is what want to say .Also photos of bolt areas
Old 02-06-2021, 12:46 PM   #12
gdmn852
gdmn852's Avatar
Old 02-06-2021, 02:24 PM   #13
shew01
shew01's Avatar
Originally Posted by Oldbluoval View Post
Not Brent but....
Thanks.
Old 02-07-2021, 12:58 AM   #14
Jeff M
Thanks for the replies! Where is the best place to jack up the front of the body?
Old 02-07-2021, 06:51 AM   #15
Jacksonlll
Jacksonlll's Avatar
I did it right by the engine mount. Just takes a little.
Old 02-07-2021, 10:50 AM   #16
Roger V
Roger V's Avatar
I use a floor jack and a cut-to-size 2x4. I position it under the first body cross member (near front of seat). To prevent strain I loosen most of the forward body bolts.
Old 02-09-2021, 03:47 AM   #17
Jeff M
I finally removed all the bolts, I didn’t see where to remove the one with the yellow arrow. Is this necessary to remove the fenders? Also do I need to remove the rear fenders to jack up the front of the body or is it not required? Still not to sure where it was suggested to lift the front of the body with a 2x4, I assume like I have pictured. Probably making this out to be harder than it is but I don’t want to screw anything up.
File Type: jpg 074FB0B8-6703-4D3A-B8FB-78FE74B86A48.jpg (23.0 KB, 57 views)
File Type: jpeg 2116B62E-71EC-461E-A525-4148E6277A78.jpeg (86.0 KB, 54 views)
Old 02-09-2021, 11:15 AM   #18
Jacksonlll
Jacksonlll's Avatar
I think I just put a board vertically just inside the frame. You just need 1/32in clearance. This does not involve anything in the rear.
Old 02-09-2021, 12:32 PM   #19
J Franklin
J Franklin's Avatar
Get a friend to give the body a slight boost and remove the fender.
Old 02-09-2021, 09:01 PM   #20
gdmn852
gdmn852's Avatar
Hello again, if I remember correctly,that bolt is attached to a bracket on outer edge of frame.
