01-18-2021, 09:53 AM | #1 |
C59A - Purpose of threaded holes on block
I'm nearing the final stages in the rebuild of my C59A engine, and while working on mocking parts to the block I noticed four large tapped holes on the block near the water pumps. I'm getting ready to paint the block, and was just wondering what the purpose of these threaded holes.
01-18-2021, 10:06 AM | #2 |
Re: C59A - Purpose of threaded holes on block
Per Joe Abbin's book, Ford & Mercury Flathead V-8 Identification & Rebuilder's Guide, figure 2-5 page 2-5, those four holes were used for the front engine supports on 32-36 model engines and carried over on all later models. Thus later engines can be installed in early cars using the original mounting brackets.
Also, in my opinion, they are fine, stout holes for lifting the engine from the front face. Last edited by Zeke3; 01-18-2021 at 10:09 AM. Reason: added opinion |
01-18-2021, 11:38 AM | #3 |
Ok. Thanks. I quickly checked the two books I have and didn't see any mention of it. I'm guessing this hole is for the same purpose.
01-18-2021, 11:39 AM | #4 |
that hole is for a drain pet cock for the engine block, most people just put a brass plug in the hole
01-18-2021, 11:40 AM | #5 |
That one [it has a mate on other side], is so you can drain coolant from block
01-18-2021, 11:43 AM | #6 |
01-18-2021, 12:20 PM | #7 |
I think I have heard that the '53 pickups had a one-year only motor mounting system that used these front holes. Any body know for sure?
01-18-2021, 12:34 PM | #8 |
Thanks guys. Good thing I had a peek as I would have never known. This is why this site is so great!
01-18-2021, 01:27 PM | #9 | |
Early Motor Mounts Factory Engine Transport on brackets utilizing those holes, below! |
01-18-2021, 02:37 PM | #10 |
Haha! Reminds me when we were asked to add some holes in certain sheet metal parts by our powder coater.
01-18-2021, 02:54 PM | #11 |
Yes, and the later Y-blocks retained the system
'52 F-1, EAB flathead |
01-18-2021, 06:13 PM | #12 |
Heres mine. Also those four holes can be used for making your own engine stand if you have no waterpumps fitted.
01-18-2021, 07:35 PM | #13 |
I used the two right holes (as viewed from the flywheel) to mount the pointer for TDC.
01-18-2021, 08:06 PM | #14 |
01-19-2021, 10:31 AM | #15 |
Yep, nice engine 34 Gaz. Very close in colour to mine. I wonder why none of this info is mentioned in the two flathead books I have?
