Old 01-08-2020, 09:49 PM   #1
Harpkatt
Harpkatt's Avatar
Default Stuck front drums.
This has been addressed a million times. And yet here I am. About a year ago I purchased a "doodlebug". As you can imagine this probably hasn't had an easy life. When I got it it had barely any front brakes and had no backing plates in the rear. I swapped in a new rear axle and brakes. And am trying to fix up the fronts. But I can't get the drums off. I loosened the adjuster on both wheels and the wheels spin freely. Removed the hub nuts and washers and those drums won't budge. I tried heating them gingerly tapping on them with a hammer and wooden board. Is there any more radical way to get these off?
Last edited by Harpkatt; 01-08-2020 at 09:52 PM. Reason: Double post please delete
Harpkatt is offline   Reply With Quote
Old 01-08-2020, 10:31 PM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Stuck front drums.
Can you get the outside wheel bearing off? Is Is the drum still hanging up on the brake shoes?
Mike Peters is offline   Reply With Quote
