Old 09-03-2019, 06:59 AM   #1
History
History's Avatar
Default (GAV) no response
I just rebuilt the zenith and it runs and idles well. I tried to adjust and even closed the gav and nothing changed at all. I do not have a screw in seat for the gav. I am going to check and make sure it is bottoming out and adjust if need be but is there anything else I need to look for? Like I said, it runs great so I don't want cause problems.
History is offline   Reply With Quote
Old 09-03-2019, 07:06 AM   #2
rocket1
Default Re: (GAV) no response
running an air cleaner? made sure all passages in body are open? are you sure it doesn't require a seat?
rocket1 is offline   Reply With Quote
Old 09-03-2019, 07:30 AM   #3
History
History's Avatar
Haven't put a cleaner back on it. It has one but so far I've left it off. There is no screw in seat or jet for the gav, it's milled into carb body.
It's possible I'll have to do some grinding on parts of the gav needle to get it to go deeper. I saw a post of this being done and it seems simple enough
Old 09-03-2019, 07:42 AM   #4
Joe K
Joe K's Avatar
Sounding like a Model B carburetor. The internal threaded GAV bushing is "pressed" in to the body and there was a spring and washer underneath it?
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 09-03-2019, 07:43 AM   #5
ryanheacox
ryanheacox's Avatar
Do you have a link to that post? Mine has a sizeable step in it.
ryanheacox is offline   Reply With Quote
Old 09-03-2019, 08:13 AM   #6
History
History's Avatar
I'll see if I can find it, I may have deleted it. But it'll be in the thread where I was asking for help while rebuilding my carb.
Joe, my carb says zenith 2 on the side.
Old 09-03-2019, 08:18 AM   #7
History
History's Avatar
Here you go, close to the bottom of the page. http://www.santaanitaas.org/wp-conte...etor-11-07.pdf
