02-17-2017, 05:40 PM | #1 |
Turn signal flasher
He is using a 3 terminal flasher, thermal type. The turn signals work A-OK. The problem is, we have have a 200 ohm path to ground on the turn signal power lead. What we found was 200 ohms across the X (power in) and P (pilot) terminals on the flasher. Has anyone come across this problem with a thermal type flasher? Thanks, Herb |
Thread Tools | |
Display Modes | |
