Old 05-31-2016, 05:40 AM   #1
2rosella
Default What is the correct timing Advance setting.
2rosella is offline   Reply With Quote
Old 05-31-2016, 05:50 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: What is the correct timing Advance setting.
Most folks feel the static timing should be TDC. Many folks then use full advance [40º] when running at highway speeds. So TDC at idle and 40º at around 1700-2000 RPM or so.
45-50 MPH is cruise speed for me and I set the lever at 1/2 for plucking around town and 2/3-3/4 for cruise. I don't feel these monsters need 40º of advance.
Old 05-31-2016, 07:54 AM   #3
barkleydave
barkleydave's Avatar
Seems like Model A's have their own "Sweet Spot" My truck likes 3 degrees retard for start and smooth low idle. Using a timing light that gives me approx. 33-35 degrees at 3/4 advance. Mine does not like 40 degree advance. Mine is org. spec. motor and it likes to cruise on the level at 42-45 mph. On a good day it will run up to 50+ but it is not happy there and is pretty maxed out. (And so am I... ! )
barkleydave is offline   Reply With Quote
Old 05-31-2016, 08:59 AM   #4
Bob from Northport
Bob from Northport's Avatar
You will find that an advance of 22 to 25 degrees at idle will give you an easy start with the spark retarded, and good power at 45 to 50mph. Just make sure you have TDC marked and painted exactly on the crank pulley.
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 05-31-2016, 09:39 AM   #5
Jerry in Shasta
Jerry in Shasta's Avatar
I do it a little different. I set my timing for a max of 25-28 degrees.
The engine has been "warmed" considerably.
It does not like any thing over 30 degrees. By doing it this way,
I do not run the risk of damaging the engine by over advancing.
JB
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 05-31-2016, 09:44 AM   #6
wmws
My car starts and idles nice at 0 degrees at TDC. On the highway I don't advance over about 3/4 down with the lever or 30 degrees. I have never heard it pinging but I am a little hard of hearing. Does anyone else actually hear pinging when cruising down the highway?
wmws is offline   Reply With Quote
Old 05-31-2016, 11:08 AM   #7
tbirdtbird
let us know how you make out
'31 180A
tbirdtbird is offline   Reply With Quote
Old 05-31-2016, 11:19 AM   #8
PC/SR
When I first started to heat up the engine with an HC head and dual carbs, I kept the original distributor and came to not only appreciate the flexibility of playing with the spark lever, but also learned a lot about the engine and performance by trying it in different positions. (ie, full retard going down hill.) Use it about 25-30* max, timing should be retarted as comp ratio increases.
PC/SR is offline   Reply With Quote
Old 05-31-2016, 11:58 AM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
Someone once mentioned they had a lock (small clamp) on the spark quadrant so the lever could only be moved down so far. That would be a good idea for many from what I read as far as too much spark advance being used.
Old 05-31-2016, 12:19 PM   #10
Mitch//pa
I never go past Half way and if i do it's very brief. Stock or hc head
Many folks start up and yank it all the way down lol
Old 05-31-2016, 12:33 PM   #11
Anteek29
Anteek29's Avatar
My '29 with HC head likes it best with advance lever set about half while running at 45-50 mph.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 05-31-2016, 12:53 PM   #12
Mitch//pa
And of course everything depends on how accurate your base timing is set .. IE lever setting etc
Old 05-31-2016, 12:54 PM   #13
CarlG
CarlG's Avatar
I've used one of these with a set screw. Works very well and removable whenever.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-31-2016, 02:03 PM   #14
Patrick L.
Patrick L.'s Avatar
Boy, I find this very interesting. Many times in the past when I mentioned this subject I was criticized [ thats fine] by many. Then most folks seemed to have to use full advance.
Old 05-31-2016, 02:10 PM   #15
Mitch//pa
We're allowed to talk about it,, but your not
Old 05-31-2016, 02:25 PM   #16
Patrick L.
Patrick L.'s Avatar
Boy, I've heard that about a lot of things for a long time !
Old 05-31-2016, 02:43 PM   #17
tbirdtbird
'31 180A
Old 05-31-2016, 02:50 PM   #18
George Miller
George Miller's Avatar
You will never get most model a guys to under stand what timing is all about.
George Miller is offline   Reply With Quote
Old 05-31-2016, 03:45 PM   #19
JOHN CT
JOHN CT's Avatar
I've been following this thread so I was curious. I have the Nerex timing gauge installed. Went out to the A ,dugout the old timing light.Fullretarded it's at 10 btdc to fully Advance at 35 atdc it runs great ( I think) What are your thoughts?
Thanks
I forgot to mention it's a stock motor
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 05-31-2016, 03:53 PM   #20
mshmodela
mshmodela's Avatar
I guess I'm a timing cheapo, I advance it from the fully retarded position about 1/3 (down) and I know from my driving which is all city I hardly ever go more than 1/2 advanced..
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
