Old 02-02-2015, 11:48 PM   #1
2rosella
Default Temperature probe position question.
2rosella is offline   Reply With Quote
Old 02-03-2015, 12:08 AM   #2
31 Vicky
Default Re: Temperature probe position question.
The temp probe should be at the water outlet.
I am using the Vintage Precision thermostat housing that incorporates a port for the probe, a great solution.
A's Always
Dave
31 Vicky is offline   Reply With Quote
Old 02-03-2015, 12:55 AM   #3
Y-Blockhead
Y-Blockhead's Avatar
I just finished installing a mechanical temperature gauge. I have a water outlet neck with a tapped hole for the probe.
Old 02-03-2015, 01:01 AM   #4
Mike V. Florida
Mike V. Florida's Avatar
Outlet.
If a probe is places in the inlet it will measure the cooled water after passing through the radiator. The outlet will give you the temperature of the water after being heated by the engine. I guess one could install both and see how effective the radiator is working.
Old 02-03-2015, 01:31 AM   #5
CarlG
CarlG's Avatar
Here's mine: (same as Post #2)
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-03-2015, 12:00 PM   #6
Purdy Swoft
Purdy Swoft's Avatar
I use the probe pipe that fits in the upper radiator hose . You cut the upper hose and slip the probe pipe between the two pieces of the upper hose. All that you will need is the probe pipe and a couple of extra hose clamps . This is the easy, least expensive way to go. The probe pipe removes the risk of breaking the expensive upper water outlet. Heat rises and the probe pipe puts the probe at a good spot that isn't very noticable .
Old 02-03-2015, 01:00 PM   #7
George Miller
George Miller's Avatar
I just drill and tap my water out let.
George Miller is offline   Reply With Quote
