Originally Posted by Kilohertz
Thanks Jim. What I have read is the late 80's and into the 90's GM ECM is desirable. I have a 1995 GM1500 with a 350 in it, would that make a good donor for distributor and ECM? Is it the same vintage you were thinking of?
I have the Offy and Fenton 4 bbl manifolds, I'm sure one of them would work...and yes, I am looking for either a 2.8L or 4.3L TBI body.
Would this suggest you are using a "speed density" system,or does the MAF system use MAP sensor as well?
Thanks for the guidance Jim.
Cheers
yep that system will work well and you have all the sensors . a harness from Larrys and yer done .....
