Old 05-24-2020, 07:22 PM   #1
Steve Plucker
Default 1928 Open car door latches
Guys,
This should be a no brainer and an easy disassembly...
On the back side pf the 1928 inside door latches for Open Cab, Roadster and Phaeton is a rectangular "gaurd" that covers the working parts of the latch.
I have removed the split rivet on the front side of the latch thinking that it would then come off...wrong.
Have used a punch to drive down the cover...will not budge.
It should just come apart but it does not.
What am I not doing to get this off so I can get the handles plated?
Thanks.
Pluck
Old 05-24-2020, 08:14 PM   #2
chrs1961815
chrs1961815's Avatar
Default Re: 1928 Open car door latches
You should ask oldbluoval - he rebuilt mine and he knows latches very well.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 05-28-2020, 12:29 AM   #3
Wagga A'er
There are some little tabs that come through the back plade. You may need t make sure they have not been taped over so they do not let go. I ground mine back with a light grind and then taped tem out. be careful as there are two strong springs inside when it comes apart. good luck.
Wagga A'er is offline   Reply With Quote
Old 05-28-2020, 07:38 AM   #4
Steve Plucker
Got them off but was a challange...had to drill out the large single tab.
Pluck
Old 05-28-2020, 07:57 AM   #5
Tim Ayers
Interesting. When you say rebuilt, does he make a new or source a bolt/catch (not sure what that part inside that latches is call-haha)?
Old 05-28-2020, 08:25 AM   #6
hop up
hop up's Avatar
Tim is this the part your referring to
Wanted flathead speed equipment Thanks
hop up is offline   Reply With Quote
Old 05-28-2020, 10:05 AM   #7
Tim Ayers
Yes. Would you have some available?
Old 05-28-2020, 07:01 PM   #8
Wagga A'er
Steve be careful that rivet that holds the handle is a stepped rivet. You should be able to get one from the suppliers over there. I had to make them for my car. I used a square shaft flat head screwdriver held in a vice to help push against the latch while seating the cover back in place.
Good luck.
Old 05-28-2020, 07:40 PM   #9
hop up
hop up's Avatar
Tim let me check how many I have left from my run on them. How many do you need left or right . We made them out of O-1 and RC of 50 and exactly like originals. It’s very handy to have a machine shop
Old 05-28-2020, 07:41 PM   #10
Tim Ayers
Wow, great. Just one left and one right. One of mine is a tad worn.
Old 05-28-2020, 09:44 PM   #11
Steve Plucker
Are these for the 1928 Open car door latches?
How many do you have Hop Up?
Thanks.
Pluck
