10-20-2017, 06:03 AM | #1 |
Timing gear torque.
When I put 100 ft lb on that nut to tighten it, should I use a rag in the teeth or will the fiber teeth handle it? Don't want to mess up a new gear.
10-20-2017, 07:36 AM | #2 | |
Re: Timing gear torque.
Someone holding with the crank, will allow you to torque it to 100 Ft Lbs! Daves' Wife held it for him DON'T MESS with that WOMAN!! Bill W.
10-20-2017, 08:45 AM | #3 |
Thw rag trick will let you torque the nut, BUT you will need a dentist in the future to repair broken teeth! Put the car in gear, chock the wheels with big chocks. Maybe using a rattle gun would work with guessing how tight to get it ?
10-20-2017, 09:08 AM | #4 |
I wedged a 2"x4" between the block & crank, it worked great.
10-20-2017, 10:21 AM | #5 |
Ok, I'll do it that way, but it means I load up those fibres gear teeth. They must be strong enough. Thanks
10-20-2017, 10:39 AM | #6 |
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
10-20-2017, 10:46 AM | #7 |
Same thing. The crank gear holds the fiber gear. No way to hold just the cam. It must be ok.
10-20-2017, 10:47 AM | #8 |
I would use an aluminum or bronze gear.
10-20-2017, 11:16 AM | #9 |
The only good way to do it is take the side cover off and put a clamp across the gear below the teeth. The rag puts pressure on the teeth just like no rag.
10-20-2017, 11:41 AM | #10 |
I believe Dan McEachern recommends the same as George.
Bob |
10-20-2017, 11:57 AM | #11 |
Why not use an impact wrench? John
10-20-2017, 01:59 PM | #12 |
10-23-2017, 12:33 PM | #13 |
New question. I saw on a video where the guy put a big washer on before he put the nut on. Is this right? Snyder's does not offer one. Help.
10-23-2017, 01:42 PM | #14 |
