Old 03-09-2024, 11:18 AM   #1
springerpete
springerpete's Avatar
Default 40 wt synthetic hydraulic fluid
I need it for my Stipe shocks. This is what they use. I have tried many, many sources. Tell me where you have found it please. Thanks, Bill
springerpete is offline   Reply With Quote
Old 03-10-2024, 10:12 AM   #2
rotorwrench
rotorwrench's Avatar
Default Re: 40 wt synthetic hydraulic fluid
With modern fluid types it might be easier to find using international standards for viscosity. Try ISO 150 since it is approximately the same as SAE 40. Synthetics are more expensive than mineral based oils. Either should work OK.
Old 03-11-2024, 04:47 AM   #3
Kurt in NJ
Kurt in NJ's Avatar
Tractor hydraulic oil, I have started using Kubota hydrostatic multi viscosity in my original shocks
Old 03-11-2024, 11:25 AM   #4
rotorwrench
I've used several different commercial hydraulic fluids over the years and have noted that most of them are lower viscosity types. ISO 150 or SAE 40 is about the most viscous type available. This makes it more difficult to source since there is a lower call out for the type.
In aviation, MIL-H-5606 was and still is used for most all light weight aircraft and it is a mineral base that is red in color. The heavy aircraft went to Skydrol years ago since it is temperature stable and synthetic with fire resistance being a necessity. The stuff will strip paint though so leaks have to be repaired quickly.
Commercial fluids generally are not going to be used in areas where flammability is a problem. Most are still mineral based. Tractors and heavy equipment use large quantities of the stuff so synthetics are generally much more of an expense than necessary for equipment that uses such large quantities. Synthetics are being used more and more but still not as common as mineral based fluids.
Old 03-11-2024, 11:49 AM   #5
Y-Blockhead
Y-Blockhead's Avatar
Could a Synthetic Gear Oil, such as Super Lube ISO 120 be used?
https://www.amazon.com/Super-Lube-54...zcF9hdGY&psc=1
Old 03-11-2024, 12:51 PM   #6
Y-Blockhead
FWIW, Ford Garage suggests Schaeffer #264 ISO 150 for Stipe Shocks, if you can find it, I couldn't.
