Old 05-18-2022, 09:09 AM   #1
Zeke5180
Default Hard brake pedal
I've converted my 37 ford mechanical brakes to hydraulic drum brakes, not power assisted. I'm using a mustang master cylinder with 1/4" lines and have a 10 lb residual valve installed. The conversion kit is a Boling Brothers product whose recommendation was for the 1/4" line. Original wide five drums have been retained. Brakes are operating fine when I first start driving but after 35 to 45 minutes the pedal is rock hard at the top. The car still stops but with an effort. Letting it sit for an hour and the brakes are back to normal. Has anyone had a similar situation? Any suggestions? I appreciate any help.
Zeke
Zeke5180 is offline   Reply With Quote
Old 05-18-2022, 09:17 AM   #2
flathead4rd
flathead4rd's Avatar
Default Re: Hard brake pedal
Just a guess but I would think it has something to do with the residual valve. I have front disc and rear drum on my 50 and am using the original master cylinder with the residual valve removed from the master cylinder. Been working great for 20 years.
flathead4rd is offline   Reply With Quote
Old 05-18-2022, 09:31 AM   #3
joe 1950
joe 1950's Avatar
did you over fill the master cylinder make sure it has at least 1 inch or more room for expansion for when the brakes get hot my good friend had done a complete resto on his 40 cpe and the same exact problem as you we drained out some fluid and everything worked great
joe 1950 is offline   Reply With Quote
Old 05-18-2022, 10:55 AM   #4
Doublepumper
Doublepumper's Avatar
It's possible there is insufficient clearance between the master cylinder piston and the actuating rod. As the fluid heats up the lack of clearance there could cause the brakes to drag. I like to set them up with about a quarter inch of free travel at the pedal. Good luck!
Ever stop to think and forget to start again?
Doublepumper is offline   Reply With Quote
Old 05-18-2022, 01:27 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Zeke ...."Doublepumper" has hit the nail on the head as far as what is causing your problem. Only thing I would suggest doing differently from his remedy would be to adjust the "free-play" between the end of the pushrod and piston at about 1/8" MAXIMUM. Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 05-18-2022, 01:38 PM   #6
Mart
Mart's Avatar
Look for a little "blip" of fluid inside the master cylinder as you start to move the pedal. This shows the recuperation port is clear.
Just try slackening the push rod a little to see if it helps.
Old 05-18-2022, 02:53 PM   #7
richard crow
remove the master cyl cap. now remove a brake line from it. using a low pressure air supply blow in were you removed the line. you should see bubbles if you don,t the push rod adj is to long. also you can buy a gauge just for the perpose af making this adj. it,s cheap & very e z to use
richard crow is offline   Reply With Quote
Old 05-19-2022, 07:26 PM   #8
cadillac512
cadillac512's Avatar
Yes, need more play in the pushrod. Make sure the rod moves just a bit before it starts moving the piston in the master cylinder. Loosening the locknut and shortening the rod a turn or two will fix you up.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 05-19-2022, 07:49 PM   #9
paul2748
paul2748's Avatar
would never have the fluid an inch down from the top. Sure, maybe a 1/4 inch.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 05-19-2022, 08:26 PM   #10
Flathead Fever
Flathead Fever's Avatar
Hay Zeke, I was and ASE certified Brake Specialist and a dual Light duty vehicle and heavy truck Master Mechanic for 30-years. In my world, I only worked on factory unmodified vehicles, so I didn't need to be a brake engineer.
I have had 15 early Mustangs and I have rebuilt lots of their master cylinders. I think they all have a residual valve inside of them. These photos are from my 1970 factory Ford Mustang shop manual. The combination of two of them is probably too much pressure for the springs to retract the shoes. Take that extra valve out.
All drum brake vehicles have a residual valve that holds some pressure in the system
This keeps the rubber cups pressed tightly against the cylinders' walls so they don't leak when your not applying pressure. It will hold pressure in the system for days or even weeks. This prevents the cups from leaking but also prevents moisture from being pulled back into the hydraulic system. Maybe the combination of two valves holds the shoes out while the brake fluid is hot but as the fluid cools it shrinks taking up less room in the cylinders and lines which allows to shoes to return. If you have a car not driven very often get in it every once in awhile and stomp on the brakes to reset that residual brake pressure.
As far as the line size depends on the wheel cylinder size. Early Fords used 1/4" lines where as Mustangs and most newer cars use 3/16". 3/16" is probably okay for early Fords but since the engineers used 1/4" on the Early Fords I would go with that. Where you might have a problem is if the Mustang master cylinder has 3/16" fittings and the wheel cylinders have 1/4" If that is the case you are going to need adaptors for the master cylinder. The F-800 trucks where I worked had very large wheel cylinders, two on each wheel if I remember correctly and they used 1/4" lines. The pressure will remain the same regardless of the line size but the 3/16" lines would restrict the flow to the large wheel cylinders which could cause a momentary delay in braking.
If you look at the photo that is a combo disc brake and drum master cylinder The disc brake is always the rear portion of a dual master cylinder. You will notice there is no residual brake valve on the rear port. That is because disk brake caliper pistons have no return springs they rely on the square seal in the cylinder twisting as the pistons moves outward and the seal un-twisting is what pulls the piston back .005, just enough that the front pads don't make contact A residual brake valve would hold the pads against the rotors all of the time and wear them out.
I'll go see if I can find my boxed '65 Mustang shop manual upstairs in the garage and see if they show an internal residual valve in the single master cylinder.
They show one but they are calling it an outlet check valve in the illustration and a residual valve in the description. There are no specifications in there for the pressure rating but if it is good enough for Mustang drum brakes, it will work with your drum brakes.
I'm curious since you didn't stay with the traditional Early Ford master cylinder why use a single Mustang master cylinder instead of one for a dual primary and secondary system, it's a lot safer. Besides having a wheel cylinder leak all your fluid out of a single system you can hit something and have it take out a steel brake line or even rip a hose off and then you have no brakes. Every once in awhile it happened at work. If they make a Mustang dual drum brake master cylinder with the same mounting and piston size I'd use it instead.
Others have said it but I'll repat it you need some air space in the master cylinder resevoir and you need just a little free play in the pedal rod, just a little, you don't wan tit falling out. Just enough to make sure the master cylinders' piston is coming all the way back against the snap ring, It it does come "all the way" back the piston cannot uncover the little port that allows the fluid to go from the cylinder back into the reservoir. After a few pumps of the brakes they will be locked up solid and you will not be able to move the vehicle without opening up a bleeder. I don't think this is what's happening to you since you drive it for along time and the pedal eventually gets hard but they are not completely locking up.
Flathead Fever is offline   Reply With Quote
Old 05-21-2022, 09:36 AM   #11
joe 1950
joe 1950's Avatar
Hi paul2748 i’ve been a certified service tech for 52 years can’t count how many brake jobs and restos i’ve done and always have left fluid 1 inch below top of fill plug never a problem look at your new car the fill line is just about the same at least it is on my Dodge truck and Nissan
Old 06-29-2022, 03:07 AM   #12
Zeke5180
Thumbs up Re: Hard brake pedal
Just wanted to update on the progress of the hard brake pedal problem. I took the advice of several on the forum and shortened the push rod for the master cylinder. Shortening the push rod did the trick. Thanks to all for your help and advice.
John Z.
Old 06-29-2022, 06:48 AM   #13
Mart
Mart's Avatar
Glad it worked for you.
Old 06-29-2022, 10:01 AM   #14
RKS.PA
RKS.PA's Avatar
Excellent!! And that was the easiest of all the proposed solutions!!
RKS.PA is offline   Reply With Quote
