Old 01-02-2020, 01:44 PM   #1
Phred
Phred's Avatar
Default ARP Head Studs
Months/years(?) ago I remember someone having kits of ARP cylinder head studs for the Model A engine. The broached allen key end would be nice in this application.
If this sounds familiar, any sourcing would be appreciated.
Thanks ins advance.
Peace, Phred
Phred is offline   Reply With Quote
Old 01-02-2020, 01:57 PM   #2
johnneilson
Default Re: ARP Head Studs
Phred,
to the best of my knowledge, ARP does not sell a kit for the studs on Model "A or B".
someone like Synders might.
now, with experience in ARP fasteners, I can suggest this;
do some measuring and determine your requirements for length(s)
search web sites such as summit racing or jegs to find the individual pcs.
if you order directly from ARP and do not have a resellers account, you are paying list price.
PS, stay with 55ft/lbs torque, any more just distorts the deck and head no matter what stud/bolt is used.
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is online now   Reply With Quote
Old 01-02-2020, 04:51 PM   #3
denis4x4
denis4x4's Avatar
I got mine from ARP along with stainless acorn nuts and washers
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 01-02-2020, 05:18 PM   #4
Phred
Phred's Avatar
Thanks guys.
Old 01-03-2020, 08:24 AM   #5
Nosetime
Nosetime's Avatar
Reds Headers has the kit, nice tube headers and some other 4cylinder stuff. Victor is a nice guy to deal with. 760-343-2590.
Nosetime is offline   Reply With Quote
Old 01-03-2020, 12:17 PM   #6
Jim Brierley
Amen to what Nosetime said!
Old 01-03-2020, 04:20 PM   #7
johnneilson
Holy smokes, didn't know Red's had the kits
John
Old 01-04-2020, 12:02 PM   #8
Jim Brierley
John,smokes have no tensile strength, stay with the ARP.
Old 01-04-2020, 04:27 PM   #9
johnneilson
Funny Jim, I thought smokes are grade 2............
J
Old 01-05-2020, 10:30 AM   #10
rotorwrench
rotorwrench's Avatar
It's too bad that unified hardware in this country has become harder to get. There was a time when you could go to any auto parts store and purchase bolts & studs in most common lengths, grades, and even oversizes of shank & thread. I can still get some for the aircraft engines but even those are getting scarce unless the engine is still in wide use.
Studs are set in to a specific torque before bottoming out in the aircraft engines. If they bottom out they will become loose in the bore so oversizes were available to get them to set correctly. I don't think Ford ever did this. I always made my thread clean out tools from old bolt to keep from making the threaded bores too large for new studs or bolts. Ford made some damn good hardware back in the day.
Old 01-05-2020, 12:51 PM   #11
Jim Brierley
John, I once replaced some 1" bolts on a big-rigs rear suspension. The bolts in the stockroom were grade 2. I was using a 1" drive socket set, and never even felt them get tight! They just stripped the threads right off!
Old 01-05-2020, 03:26 PM   #12
Cape Codder
Cape Codder's Avatar
rotorwrench Statement from above: "I always made my thread clean out tools from old bolt to keep from making the threaded bores too large for new studs or bolts." Is there anything special in this process and if so any pictures/drawing? Thanks!
Cape Codder is offline   Reply With Quote
Old 01-05-2020, 06:42 PM   #13
rotorwrench
I just cut flutes in the bolts used for clean out a lot like a tap is set up using a carbide cutting wheel. The OEM hardware has the correct thread pitch grade for the threaded hole so it has no tendency to cut at the threads. Thread taps are sometimes a larger fit grade than they should be and they will cut the threads deeper. It's just to clean the crap out. The rest will blow out with compressed air. This insures the thread pitches will remain as tight as possible. It's important for studs to be relatively tight. Loctite might work but it depends on a lot of factors on how well it works.
Old 01-06-2020, 09:45 AM   #14
Nosetime
Nosetime's Avatar
I did the same thread tool from original stud as Rotorwrench. Very important tip there!
Old 01-06-2020, 03:42 PM   #15
Cape Codder
Thanks rotorwrench!!
Old 01-07-2020, 12:38 PM   #16
Jim Brierley
I do as rotorwrench does, on camshaft nuts, to clean the cam threads. As accurate as most things are machined, cams are different. All threads are not the same, only close. Same with the 2 dowels, most are 5/16", .312" but I've found many that are only .310". Some holes get worn, probably from being a bit loose. For these, I make oversize dowels, both in diameter and length.
