Old 12-26-2016, 02:17 PM   #21
Fred K-OR
Fred K-OR's Avatar
Default Re: Removing stuck parts
Originally Posted by DougT View Post
My trick for pistons is to pour an inch or so of Kerosene in the bore. Diesel fuel will work, just don't use gasoline. Clean/scrape around the edges of the pistons first. Use a piece of paper as a wick and light the kerosene. Let it burn out and then take a block of wood about the same diameter as the piston an d try to drive it out. Sometimes it takes a few tries at the kero. The burning kero heats the block, the liquid kero helps keep the piston cool, and as the kero boils it thins out and goes down past the piston. I've had good luck with this method in all types of engines. Of course, this doesn't work so good if the pistons are at the top.
I used a similar method years ago on a Model T engine years ago. I just used penetrating oil for a period of time then used a 4 x 4 to tap the pistons and they came out.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 12-26-2016, 02:22 PM   #22
Mitch//pa
Dave I was thinking of using the inductor with the long wire that can be formed... i bet it would work
Old 12-26-2016, 03:03 PM   #23
tbirdtbird
Originally Posted by Flathead Dave View Post
Have you been rocking the crank back and forth after letting the pistons soak for a while? A machine shop can also get them unstuck.
#18 the crank is out
'31 180A
tbirdtbird is offline   Reply With Quote
Old 12-26-2016, 03:09 PM   #24
Synchro909
Synchro909's Avatar
Seems there are lots of opinions here so I'll jump in with yet another take on it. If the motor was outside all those years without a head on it, it's gonna need a rebuild anyway. I can't see the bores being serviceable let alone the likely circumferential groove the rings have likely left in the bores. That alone would require a rebore to cure.
So, if it is going to have to be reconditioned, I wouldn't go to much trouble to save the old pistons nor even the con rods. They are easy to find and cheap. When I am rebuilding a motor, I use new rods, not eighty something year old, fatigued ones.
I see no down side to destroying the pistons to get them out. If the rods are damaged in the process, so be it.
All that is if you insist on using THAT block. If it is the number correct one for that car, fine but even another engine might be better in the long run.
Just thinking outside the block!! FWIW
Old 12-26-2016, 04:44 PM   #25
Tom Wesenberg
Tom Wesenberg's Avatar
I was also wondering if dry ice would cool some parts so quickly that they might crack?
With an engine setting outside for so long with no head, I'm wondering just how much can be saved?
Do you have any pictures, especially of the pistons and cylinders?
Old 12-26-2016, 08:21 PM   #26
Cool Hand Lurker
Cool Hand Lurker's Avatar
If you want to cool something don't bother with the dry ice or water. Just use your air compressor hose.
Cool Hand Lurker is offline   Reply With Quote
Old 12-26-2016, 09:49 PM   #27
robgross1930
Originally Posted by jhowes View Post
I would like to clear things up a bit. The crank is out, all I have is the block and the stuck pistons in the block. The motor was rebuilt ( whatever that means besides new rings) and left outside for years without a head on it. Go figure. I have been soaking it with acetone and
atf fluid for a week or so now and will continue for another month or more if necessary. I had made up round 1/4" steel plates to put in the cylinder to pound on instead of the pistons directly. That way it spreads the force of the pounding over the entire surface of the pistons, hopefully saving them from breaking. It worked on a previous engine so time will tell. I find that wood breaks easily when used as a striking tool, maybe I will try some oak or other hard wood. One last idea, would Evaporust work and free the rings from the cylinder walls? Thanks for all your suggestions. Jack
Believe it or not, what has always worked for me is used motor oil. Yes, you heard right, used motor oil!
Used motor oil contains a mild acid that is a by-product of combustion and it will help to free the pistons. By used, I mean oil that that needed changing that turned black. Let her soak.
robgross1930 is offline   Reply With Quote
Old 12-26-2016, 10:15 PM   #28
Tom Wesenberg
I've heard you should use the dirtiest used diesel oil you can find. I've never tried it, so I can't say if it works, but other have had success.
Old 12-26-2016, 11:46 PM   #29
Synchro909
Synchro909's Avatar
A couple of years ago, I had to dismantle an engine that had sat in a shed since the 1950s. I was in no hurry to get it apart so I poured a little old engine oil over the head studs and everything else I could see externally and left it for a couple of months. Every nut/bolt unscrewed like they were assembled yesterday. If you have time on your side, you don't need fancy penetrating fluids.
Old 12-27-2016, 09:44 AM   #30
jhowes
You have no idea how much I appreciate your comments on this. Unfortunately I will have to put this on hold as my Willys Knight is in need of my immediate attention. Thanks Jack
jhowes is offline   Reply With Quote
Old 12-27-2016, 10:16 AM   #31
Tom Wesenberg
Get the sleeve valves rusted stuck in that engine and you'd really have a problem.
Old 12-27-2016, 11:48 AM   #32
jhowes
Tom : I think I have a real problem anyway with the sleeve valve engine. It runs but has no power. You would think that a 6 cylinder would beat the pants off of a model A but I find that the sleeve valves that I have researched have no guts. Jack
Old 12-27-2016, 12:50 PM   #33
robgross1930
Years ago, I had a friend who was a Stearns-Knight expert and he used to say that the more the engine carboned up the better it ran. Apparently carbon helped to seal it.
Old 12-27-2016, 05:24 PM   #34
Synchro909
Synchro909's Avatar
I've heard that from several sources too and it makes sense. Boy, can those sleeve valve engines blow smoke!
Old 12-31-2016, 09:15 PM   #35
26 lakes
This is a thread I started on the early V8 section. I have taken EVERY engine apart even ones that have sat outside for years with no heads. Enjoy
http://www.fordbarn.com/forum/showth...+up+a+Flathead
26 lakes is offline   Reply With Quote
