Old 11-28-2020, 03:24 PM   #1
Sutton Speed
Sutton Speed's Avatar
Default Original Champion Flathead Spark Plug Question
Hey guys... So I have an original set of Champion 48-12405-A2, 6 COM Flathead spark plugs. From the little bit of info I can find on them looks like they are for earlier flatheads. Will these plugs work fine on a ‘45 59AB? See attached photos. Thanks so much for the info!
Sutton Speed is offline   Reply With Quote
Old 11-28-2020, 03:59 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Original Champion Flathead Spark Plug Question
'45 used 14mm plugs, are they 14mm? or 18mm which is '37 and older
Old 11-28-2020, 04:05 PM   #3
petehoovie
petehoovie's Avatar
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 11-28-2020, 06:04 PM   #4
Bored&Stroked
Bored&Stroked's Avatar
They're not even the correct thread size . . . you need 14mm.
Old 11-28-2020, 06:04 PM   #5
Bored&Stroked
Just run NGK B6L plugs
Old 11-29-2020, 05:54 PM   #6
Bob NH
Bob NH's Avatar
Bored & stroked has it right, these plugs are great !
Bob NH is offline   Reply With Quote
Old 11-29-2020, 06:10 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
You would probably be quite surprised at what that NOS set would be worth to a true restorer. Don't just use them in something 'cuz they fit! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 11-29-2020, 11:06 PM   #8
David J
David J's Avatar
That is the correct plug for a 1960 John Deere 630 .
David J is offline   Reply With Quote
Old 11-29-2020, 11:35 PM   #9
cadillac512
cadillac512's Avatar
And it only requires two!
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is online now   Reply With Quote
Old 11-29-2020, 11:37 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
You sure, David? That looks like a '35 Ford part number. DD
T5 W/TORQUE TUBE
Old 11-30-2020, 11:09 AM   #11
RalphG
RalphG's Avatar
They look a little short and fat compared to the J 10 or H 10 Champions we always used in the flatheads from 39 up. Still running some ancient Champions like that in the 52 Merc. and they work fine.
RalphG is offline   Reply With Quote
Old 11-30-2020, 11:49 AM   #12
Bob C
The parts book shows Spark plug-heavy duty service cars (No. 6 Com'l) 1935-36
