Old 11-28-2020, 10:10 AM   #1
Charlie ny
Default Best stock 8BA camshaft
Guys,
After 11 months of thrashing my '32 pickup is on the road. As pur-
chased it had a 286 8BA installed. The story is the motor is from a 50's
circle track car and after freshening I decided to reuse the cam,a SEARS
catalog item. The cam had .090 flats at the apex of each lobe which I
thought would give a nice rumpy idle. The motor certainly has a rumpy idle plus low power until 3000 rpm, long warm up time up before decent drivability.
I now hate this cam and in spring will change it. I'm wondering if there is a
stock cam that has a performance edge and the pt# if you please.
Gracias,
Charlie ny
Charlie ny is offline   Reply With Quote
Old 11-28-2020, 10:55 AM   #2
flatford8
flatford8's Avatar
Default Re: Best stock 8BA camshaft
I’ve read on here that EAB and 8CM were a good choice. Tilden Technologies has a good informative website with a chart that lists Flathead stock cams...... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 11-28-2020, 12:00 PM   #3
tubman
tubman's Avatar
I have an 8CM cam in my '51 Ford. The new engine I put in performs much better than the previous one did, but it has better heads, better carburetion, and better ignition, plus the old one was a little tired. According to the aforementioned Tilden Technologies information, it has better numbers than an 8BA cam (.330 lift vs .307). Tilden (at least from what I can see) has no information on an EAB or EAC cam. I for one, would like to see it. (I would expect an EAC to be "better" than an EAB, just like a 8CM has better numbers than an 8BA.)
Old 11-28-2020, 12:23 PM   #4
cadillac512
cadillac512's Avatar
Charlie, I agree with Tubman on the 8CM cam being very nice in a semi-stock engine. I am running one in a 260" Merc with good quench, a 2GC carb and Chev distributor and it performs excellently. Still a smooth idle-maybe just a tiny bit less smooth than the stock '41 Merc cam-but pulls hard from idle to 4000 rpm. From 1500-3000 it's a beast. VERY good warm up manners.
When I built the engine I checked the 8CM against an EAB cam and there is almost no difference despite what the published sources say. In fact, I would bet the difference between the 8CM and the EAB would be unnoticeable in operation...they are that close.
After using the 8CM, I would recommend it as well as the EAB/EAC.
I do like a powerful engine, and tend to use them briskly...
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 11-28-2020, 03:12 PM   #5
flatjack9
flatjack9's Avatar
The 8CM or EAB are the best stock cams you can use. I've had a Winfield SU1-A in my 39 for 25 years now and really like it. Still a good bit of low end torque. I can start out in second gear if I want too. Have a 3.70 Bronco rear axle. The L-100 is very similar. There are others that have been recommended, but I only have experience with these two. Tilden lists an "improved" 8CM, I've always meant to see if they actually will grind one.
Old 11-28-2020, 03:26 PM   #6
40cpe
40cpe's Avatar
I called Specialty Motor Cams that the Tilden site specified to inquire about the improved cam a few years ago. They told me that they would grind one. I didn't inquire about price because I was leaning toward a "rumpity" cam.
I'm no cam expert, but the Isky Max#1 looks very similar to the Tilden cam.
40cpe is offline   Reply With Quote
Old 11-28-2020, 03:46 PM   #7
flatjack9
flatjack9's Avatar
I'll have to take a run over there and talk to them
Old 11-28-2020, 06:20 PM   #8
KiWinUS
KiWinUS's Avatar
Charlie I can help if you need a nice used EAB possibly a used merc also or can grind merc fresh.
Old 11-28-2020, 06:50 PM   #9
GB SISSON
GB SISSON's Avatar
If it's ok for me to cut in, I have a question about cams.... I'm collecting parts for a 260, Had the 4" crank ground last winter. I have some nice 8ba blocks, various cams, but some have been just laying across other engine parts, not well supported. Will they sag or take a set like a crank can? If so I may be looking for a cam too. Thanks!
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 11-28-2020, 06:55 PM   #10
JSeery
JSeery's Avatar
Don't think either will.
Old 11-28-2020, 07:32 PM   #11
cadillac512
Should be fine, GB...I've never seen one bend from that type storage yet.
Old 11-28-2020, 09:08 PM   #12
Ol' Ron
Ol' Ron's Avatar
I'm really happy with the EAb cam in the 280. I;m even running rotators with stock springs and a.060" spacer. Low end torque is fantastic and it turns 4+K with no problem. It also has milled EAB heads on it. 2GC carb.
Gramps.
