Old 10-04-2020, 12:01 PM   #1
tom mcclaren
Default 1941 ford sedan vacum wiper motor and control
my 1941 ford super deluxe wiper only functions when I turn the control back and forth. There are three hoses one from manifold to switch and two from switch to vacum motor, Any advise is much appreciated.
tom mcclaren is offline   Reply With Quote
Old 10-04-2020, 03:30 PM   #2
meric42
meric42's Avatar
Default Re: 1941 ford sedan vacum wiper motor and control
Sounds like your wiper motor may need lubricated as least. I used ATF and a syringe to get the ATF in to the wiper motor (via the Vacuum feed line) by moving the blades back and forth with the switch in the on position. This worked great on my '41 Coupe. Failing this, you may need to get your wiper motor rebuilt.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
http://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 10-04-2020, 03:48 PM   #3
Jacques1960
Jacques1960's Avatar
Brake fluid is my go to for Trico motors.
No job’s done ‘til it’s all done
Jacques1960 is offline   Reply With Quote
Old 10-04-2020, 03:51 PM   #4
Jacques1960
PS - keep away from paint...maybe I should switch to ATF !
Old 10-04-2020, 04:34 PM   #5
ford38v8
ford38v8's Avatar
Don't put anything in your Trico that you wouldn't put in your engine.
Alan
Old 10-05-2020, 10:51 AM   #6
Automotive Stud
Automotive Stud's Avatar
Take the wiper motor out, you'll see a small cover in the middle of it held on with two tiny screws. Remove that cover and you should see a fiber cam with a small spring holding it, put some three in one oil on there, it should rotate side to side freely and the spring should make it snap to the sides into place when you push it with your finger. This is the mechanism that switches the vacuum to change the direction, it gets sticky and doesn't switch.
Automotive Stud is offline   Reply With Quote
Old 10-05-2020, 11:03 AM   #7
TJ
TJ's Avatar
Marvel Mystery Oil also will lubricate the wiper motor.
Old 10-05-2020, 11:16 AM   #8
rotorwrench
rotorwrench's Avatar
It may have a problem with the valve as well. I think Ford only used that set up for the one year and then they went back to a linkage that pulled the valve on the wiper motor but I don't know for certain how long they used it. Make sure there are no rubber tube leaks and test the valve if you can. It seems like they had two larger tubes and one small one.
rotorwrench is online now   Reply With Quote
Old 10-05-2020, 05:52 PM   #9
corvette8n
corvette8n's Avatar
When I forced Marvel Mystery oil into the vacuum line from under the hood using a syringe, I had a puddle of oil on my interior floor, hose was cracked under the dash. If those hoses are original you may want to replace them first.
Old 10-05-2020, 06:34 PM   #10
grumppyoldman
grumppyoldman's Avatar
Unless you are going for an all original car, install a 2 speed electric. After buying a NOS Trico motor and still not having a good wiper system, I replaced mine with one from Mac's works great and fit like original, no revisions. BTW I have a NOS Trico that I would part with PM me.Al
grumppyoldman is offline   Reply With Quote
Old 10-05-2020, 10:45 PM   #11
fordor41
fordor41's Avatar
If I remember correctly smaller hose will keep the wipers in the park position. so when the wiper switch is off there will be vac to hold the wipers down otherwise they would move all over, from the air across the windshield.
fordor41 is offline   Reply With Quote
Old 10-06-2020, 05:10 AM   #12
big job
big job's Avatar
All I can say is my 46 has that kind of control with three hoses.
big job is offline   Reply With Quote
