Old 08-27-2020, 03:35 PM   #1
Clem Clement
Clem Clement's Avatar
Default Horn wires
pardon my dumbness: Why doesn't the horn ground to its frame?
Old 08-27-2020, 03:50 PM   #2
Kens 36
Kens 36's Avatar
Default Re: Horn wires
The wires to the horn are hot. Your horn button provides the ground.
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 08-27-2020, 10:31 PM   #3
Clem Clement
I have 2 terminals outside the horn. One is grounded to the horn frame and the other is insulated from the horn frame and connects to the horn coil
Old 08-28-2020, 09:57 AM   #4
Bob C
xxx
Old 08-28-2020, 11:04 AM   #5
JSeery
JSeery's Avatar
Which vehicle are we talking about? Some years/models of Ford use a horn relay and some do not. In general 32 thru 37 (and some later trucks) uses a hot wire directly to the horns and then a ground wire from the horns to the button on the column. Starting is 38 Ford added a horn relay. The hot wire connects to the relay and a ground wire connects from the relay to the column button. When the button is pushed on these models it closes the horn relay which connects the hot lead to the horns and the horns have a ground connection to the frame.
Old 08-28-2020, 11:21 AM   #6
JSeery
JSeery's Avatar
If it has a horn relay, they do ground to the frame, it just may be through the bracket. The only path back to the battery is through the body/frame or a directly connected ground wire back to the battery.
Without a horn relay, the horns need to be insulated from the frame.
Old 08-28-2020, 01:11 PM   #7
Clem Clement
I'm trying to use a new -to -me horn. I'm realizing both wires to the horn should go thru insulated pots. one is not and I will fix that. It is a 39 pickup. I had a relay on an earlier horn but that quit. I found a cute little horn with a bracket that looked like if fit on a taillight, Turns out it is labeled Ford, Makes a sound like a moose ona goose. I'm guessing it is for a T. I told my clubbers it was to be mounted behind the right tail light to warn that I was turning right in Jersey into a Jug handle!!
I hope to work on it tonight
Old 08-28-2020, 06:17 PM   #8
JSeery
JSeery's Avatar
Just need to decide if you are wanting to use a horn relay or not. If you are using a relay there is no need to insulate the ground wire at the horn. If you are wiring it up directly, then insulating it would be a good idea. I thick sleeve of heat shrink might work will.
Old 08-29-2020, 01:29 PM   #9
Clem Clement
thanks. I am to old to be this dumb. When I test the horn on the bench, GREAT PPFFLATTT IS heard. When I bolt it to the frame, nothing as the horn is shorted out. duuuuh. I have some fiber washers from train repairs and carb gaskets to insulate the horn wires
Old 08-29-2020, 02:02 PM   #10
JSeery
JSeery's Avatar
Sounds a little strange, but maybe worth a try. I wouldn't think the ground point would matter, but? Can you post a photo of the horn?
Old 08-29-2020, 11:41 PM   #11
Clem Clement
Golly this task has got me big. The horn sez Ford on it. It is a squawker, not a motor. one post is insulated, the other just now is, BUT:
There is only one wire inside the horn. It goes from the insulated stud to the coil which has an iron center core. The other end of the coil goes to a vibrator with points on it.
On the bench if I ground the horn case and attach negative battery post connection, the horn squawks.
Maybe I can't use this design?
Really grinding on me
Stay safe
Old 08-29-2020, 11:59 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
First of all, what type of car are you doing this on? And what are you trying to use to 'beep' the horn....a normal steering wheel horn button? And if so, is there a horn wire coming all the way up through the steering shaft? DD
Click Links Below __
T5 W/TORQUE TUBE
V8COOPMAN is online now   Reply With Quote
Old 08-30-2020, 12:06 AM   #13
JSeery
JSeery's Avatar
So why wouldn't work the same on the car? Try setting the horn next to the car and check it with some jumper cables. Start with connecting a ground jumper from the battery to the horn. Then connect the other jumper to the horn, then touch it to the negative to check the horn. If that works, mount the horn on the car and check it again with the jumpers. If that works, hook up the horn button and try that with the ground jumper still connected. It's possible your not getting a good ground when mounted on the car.
Old 08-30-2020, 02:27 AM   #14
aussie merc
aussie merc's Avatar
im confused any chance of a photo
aussie merc is offline   Reply With Quote
Old 08-30-2020, 03:25 AM   #15
koates
Your confused ! Oh Boy I am totally disorientated by this description. Horn mounted on the tail light ! I think Clem has been on the turps. Regards, Kevin.
koates is offline   Reply With Quote
Old 08-30-2020, 08:38 AM   #16
Clem Clement
Look up hiway Jug handles in New Jersey and figure them out. Add humor to your thinking.
Old 08-30-2020, 10:34 AM   #17
Bob C
That looks dumb. https://en.wikipedia.org/wiki/Jughandle
Old 08-30-2020, 09:52 PM   #18
Clem Clement
In the old days the jug handles were helpful. Now they take up too much space and visitors don't know what to do. You thionk jug was bad, try a peanut circle!
Old 08-30-2020, 09:57 PM   #19
Clem Clement
I spent 5 hours cleaning wires and puzzling horns. I got a regular horn tuned and installed. it said Moo sow I need to readjust it. I'm thinking the funny Ford horn probably was mounted on wood someplace so the second wire was not needed. I don't know how to post photos
Old 08-30-2020, 09:58 PM   #20
JSeery
JSeery's Avatar
Did you attempt any more testing on your horn?
