Old 04-01-2020, 05:51 AM   #1
DNLs1930
DNLs1930's Avatar
Default 600w leaking out of steering box
Steering was kinda sloppy/loose so I checked the oil level and NO OIL. It was not "dry" but seems to have a little grease in the steering box. I added the 600WT oil and it is leaking so obviously the reason for the "grease".
I have read about Pinrite, Corn Head and 1200 WT grease/oil so guessing I just need to choose one.
I have also read about the wiring being affected by steering box leaks so thinking I need to take this all apart and clean then pack the steering box with grease. Yes/ No. maybe?
The steering works fine so not at a rebuild point (IMO) which is based on very limited Model A experience.
I'm located in Texas so it will get hot here and not really sure I will be cruzin in 100F+ temps but ya never know.
How does Corn Head grease hold up to higher temps? Liquefy and leak?
THANKS as always!!
DNLs1930 is offline   Reply With Quote
Old 04-01-2020, 05:59 AM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: 600w leaking out of steering box
Can’t answer about corn head but
There is a fix that entails replacing the bottom plate with one that has a tube.and seals the base
Check parts dealers
Yes grease can affect wiring
Old 04-01-2020, 06:03 AM   #3
DNLs1930
DNLs1930's Avatar
Check parts dealers
Yep I saw the end plate and tube; you think this is the more "normal" fix?
Old 04-01-2020, 06:22 AM   #4
David R.
I completely rebuilt mine and used the tube style end plate but it still leaked. Turned out the cap screws for end plate was tapped into housing and was leaking around threads. Removed screws and added sealant and no more leaks. Don’t use grease. It will work away from where you need it. Use the 600W. You can expect a little leak around sector shaft in use, but you should be able to keep bottom dry with the tube type plate and good gasket (and permatex on bolts).
David R. is offline   Reply With Quote
Old 04-01-2020, 06:28 AM   #5
rrich1
rrich1's Avatar
Get the new plate with the tube. I just replaced mine last month and it solved my leaking issues
rrich1 is offline   Reply With Quote
Old 04-01-2020, 06:53 AM   #6
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Originally Posted by DNLs1930 View Post
Steering was kinda sloppy/loose...
This is just my opinion but if the steering is indeed sloppy and loose, the steering is likely NOT working fine. I'd say you ARE at a rebuild point. You did not indicate whether this is a 7-tooth or a 2-tooth gearbox, but there is more than just adding the tube on the end. It may be that some parts may be re-usable however you probably should take the time to ensure everything from the sector bushings to the shaft bearings/bushings are within specs.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 04-01-2020, 06:54 AM   #7
old31
First, get yourself a Les Andrews red book and find out why your steering is sloppy/loose.
Then go with both Penrite and the tube and that will help.
old31 is offline   Reply With Quote
Old 04-01-2020, 10:26 AM   #8
CWPASADENA
CWPASADENA's Avatar
It sounds like you may need a rebuild of the box but in the short term, you can try to adjust it to get as much play out of it as you can then install a tube and use Penrite, Corn Head, or 1200W. All will work well but do not fill it up with grease. It will not "flow" and the internal parts will not get proper lubrication.
My opinion.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 04-01-2020, 10:46 AM   #9
Jacksonlll
Jacksonlll's Avatar
There is a fix for the leak through the sector shaft bushings. An external o ring that works pretty good. Check the catalog.
Old 04-01-2020, 12:28 PM   #10
1931 flamingo
1931 flamingo's Avatar
As above, clean the exposed wiring, install the tube assy AND PennRite steering box lube. NO leakee.
Paul in CT
Old 04-01-2020, 12:28 PM   #11
rosenkranswa
rosenkranswa's Avatar
I use cornhead grease in all of mine. Its not really a grease per se, more of a super 600W. I get it at John Deere dealers.
Wayne @ Barb
Malvern
'19 T Speedster
'26 T Touring
'29 A Roadster
'30 AA Stakebed
'30 A Pickup
'30 A Town Sedan
'31 A Station Wagon
'38 Columbia Girls bike (WWII)
'40 Elgin Boys bike (WWII)
'42 Super Deluxe Tudor
'42 Willys MB Jeep
'43 Willys MBT Trailer
'43 M3A4 Hand Cart
'43 Harley Davidson 42WLA with sidecar
rosenkranswa is offline   Reply With Quote
Old 04-01-2020, 12:39 PM   #12
DNLs1930
DNLs1930's Avatar
And THIS is why we have such awesome (people) cars!!!
I have a 2 tooth steering box installed.
I have the Les book and read about all the adjustments and was going to check/set them as well as add the grease.
I was thinking if I open up the box for the leak I might as well take it all apart and rebuild so guess I will start checking out that process as well.
As always thanks for the info and I will update as we go and will make some kind of documentation of the rebuild when that happens.
Old 04-01-2020, 12:48 PM   #13
Jacksonlll
Jacksonlll's Avatar
Grab your pitman arm and pull it toward you and away from you from the side of the car. If there is any movement in the sector shaft bushings, you must replace them. Make sure the pinch bolt is tight.
Old 04-01-2020, 09:01 PM   #14
Tom Endy
Tom Endy's Avatar
A good product to use in vintage steering boxes is Penrite lube. it is a very heavy oil, much like a grease, but it flows.
It can be procured from:
Restoration Supply Co.
15182B Highland valley Rd.
Escondido, CA 92025
800-306-7008
Not a good idea to use grease as it does not flow, and it will be pushed away from the gears.
Tom Endy
Tom Endy is online now   Reply With Quote
Old 04-02-2020, 08:39 AM   #15
DNLs1930
DNLs1930's Avatar
Escondido, CA 92025
800-306-7008
Tom Endy
Thanks I have seen a lot of discussion about this oil and maybe a new endplate seal and tube coupled with this thicker oil will solve the leak.
The grease idea seems ok but I agree it would "move" away from the mating surfaces and provide less and less lubrication over time.
Old 04-02-2020, 11:27 AM   #16
katy
katy's Avatar
I have seen chassis grease mixed w/STP used for a flowable type grease. Don't ask me the proportions, but it seems to me it was 50/50.
Old 04-02-2020, 01:24 PM   #17
1931 flamingo
Why mix up some concoction when you can buy something readily available that works?? JMO
Paul in CT
Old 04-02-2020, 02:52 PM   #18
Jacksonlll
Jacksonlll's Avatar
I used to use STP and I think it worked OK, but when a friend took it apart to put new gears in, the mess was awful. He is still trying to clean that mess up. Remember Dave???
Old 04-02-2020, 08:00 PM   #19
LeRoiGross
About 5 years ago my wife commented that my steering was loose and I needed to tighten it up. So I did. And then I replaced my Pittman arm. And then I replaced my drag link, idler balls, front end, and all the other parts I could see. This led to a complete restoration (body off), so look out what you start. And my steering still has a little play in it.
LeRoiGross is offline   Reply With Quote
Old 04-05-2020, 08:27 PM   #20
DNLs1930
DNLs1930's Avatar
