Old 11-01-2019, 10:59 PM   #1
steve hackel
steve hackel's Avatar
Default Thread size - windshield frame screws?
I am in the prosess of restoring the windshield on my 1930 A coupe and have run into a snag. The 90 degree corner braces that fit into the corners need their threads chased in order to install new screws. Can anyone tell me the size and thread count for the tap I need?
8x32 is too small and 10x32 has too many threads.
Thanks in advance, Steve
steve hackel is offline   Reply With Quote
Old 11-02-2019, 09:57 AM   #2
katy
katy's Avatar
Default Re: Thread size - windshield frame screws?
Maybe 10-24?
Old 11-02-2019, 10:21 AM   #3
Neil Wilson
Neil Wilson's Avatar
My research on the A-79405 windshield (for the 82-A, 79-A, and 85-A) show that the A-37156 angle used two 10-32 x 3/8 flathead screws.
You could call Snyder's and ask for details on their fasteners (https://www.snydersantiqueauto.com/P...ndshield-parts). They are good at providing information in my experience.
[email protected] - email contact
https://aafords.com Ford Model AA Truck Club @ aafords.com
Neil Wilson is offline   Reply With Quote
Old 11-02-2019, 11:29 AM   #4
dbaldwi3
dbaldwi3's Avatar
In restoring my Tudor I’ve found Henry liked 10-24 thread size and can be purchased through restoration supply houses.
dbaldwi3 is offline   Reply With Quote
Old 11-02-2019, 01:18 PM   #5
midgetracer
midgetracer's Avatar
I found the windshields on the 4 enclosed cars I have used 10-32 screws. also most other #10 screws on these cars are 10-32.
midgetracer is offline   Reply With Quote
Old 11-02-2019, 01:41 PM   #6
steve hackel
This is what I have found so far; the hole size is the same as a 10x32 screw/tap, and I can confirm this with a decimal # drill bit which fits perfectly. The threads per inch do not match up with a 10x24 because there are more teeth on the remaining threads of the screw than that, and a 10x24 screw does not fit even the first turn. A 10x32 screw has the same issues and binds up as it is turned - it has more threads than the original screws I removed. This leaves me to believe I am looking at a 10x28 tap and I can not locate one in any of my catalogs. At this point, it's still a guess?
Old 11-02-2019, 02:30 PM   #7
Bob C
Do you have a thread pitch gauge??
