09-01-2020, 09:57 AM | #1 |
Lug Nuts
Who sells correct fitting lug nuts or do I need to find a set of originals? I have a '29 Coupe.
Most re pops I see made today are loose fitting (slightly oversized) on the lug bolt which causes wear on either. The set I have now are like that. I have one or two originals that fit as designed but not a complete set. |
09-01-2020, 10:08 AM | #2 |
Re: Lug Nuts
I got a set of cad plated ones from Berts and they fit as they should.
09-01-2020, 11:04 AM | #3 |
Re: Lug Nuts
Thank you. |
09-02-2020, 04:45 PM | #4 |
Re: Lug Nuts
I see a post about lug nuts once in awhile and it got me to wondering.
Do people ever check closed end lug nuts for bottoming out before they seat on the taper? I have also seen reproduction nuts that did not have the counterbore on the leading edge. |
09-02-2020, 04:50 PM | #5 | |
Re: Lug Nuts
I do not know if people check but Vince Falter has a webpage on the subject. http://www.fordgarage.com/pages/dangerouslugnuts.htm Last edited by Benson; 09-03-2020 at 04:34 PM. |
09-02-2020, 07:02 PM | #6 |
Re: Lug Nuts
Tom Endy |
09-02-2020, 07:16 PM | #7 |
Re: Lug Nuts
When I was running stock model A wheels I used to use the large pattern race nuts.
They will compensate for slightly oversize holes in the wheel and still center ok. |
