10-22-2020, 04:22 PM | #1 |
41 Distributor Helmet Style - Dwell
Has anyone ever measured the Dwell on this Distributor when on the car?
Stock configuration if so a few helpful pointers would be appreciated. Bob |
10-22-2020, 04:26 PM | #2 |
Re: 41 Distributor Helmet Style - Dwell
You should have 34-36 degrees. Going off your other post if you have petronix it’s going to read much lower.
As for pointers I check them in a sun machine but on the car just hook your dwell meter up and start it. Most dwell meters you’ll have to connect to the battery as well and select that it’s a 8 cylinder. |
10-22-2020, 05:19 PM | #3 |
Thks where on the coil do you connect - I connected to the coil where the condenser is mounted. Is that the correct place or should it be the top post of the coil?
I purchased a very inexpensive dwell / tach meter and I think I damaged it. Not sure why Bob |
10-22-2020, 05:34 PM | #4 |
That connection should be correct. However, if your car is still positive ground you may need to connect the neg lead to the coil and pos to the ground to make it work. That assumes the meter will work at 6volts as well.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302 |
10-22-2020, 05:36 PM | #5 |
Most powered dwell meters are 12 volt negative ground and won't work on an old Ford. (I know; I tried.) I bought an old, non-powered dwell meter off eBay and it works perfectly. You just don't get a lot of other functions.
10-22-2020, 05:47 PM | #6 |
Could you tell me exactly what you purchased I'll look for one Bob |
10-22-2020, 06:21 PM | #7 | |
https://www.ebay.com/sch/sis.html?_n...2.m2749.l46251 |
10-22-2020, 05:57 PM | #8 |
Ive tried the dwell meter side on a flathead and could not get a result also.
Used a 12v battery supply for meter on a 6v +ve earh. Also recently tried with 12v -ve earth and no joy also. Phil NZ |
10-22-2020, 06:37 PM | #9 |
This is what I recently purchased and from all indications I damaged it connected as we discussed
Sunpro Digital Diagnostic Engine Analyzer CP7678 |
10-22-2020, 09:51 PM | #10 |
I do not check them on the car so I can not attest to what brand tester to use. I do have a digital fluke meter that does dwell but again have never used it on a car. Maybe I’ll try it this weekend.
10-23-2020, 06:05 AM | #11 |
I suggest you don't use your Fluke get something cheap and try it first
10-23-2020, 07:06 AM | #12 |
I have no need to go buy a dwell meter or use one on the car. Just thought I would try since you were inquiring.
10-23-2020, 08:28 AM | #13 |
I suggest not using your Fluke on this I wires out my fluke attemting to measure the low voltage feeding the coIL could have purely been just bad luck or something is creating large spikes on that coil that the condenser isn't able to suoress. Had a scope on it with a 20-1 Attinuator and was seeing some very halthy high frequency spikes. Just a word of caution
10-24-2020, 10:32 AM | #14 |
The old Ford/Mallory design distributors were dual point set ups so that they could get more dwell time out of an eight lobe breaker cam. If the breaker points are installed & adjusted properly per the Ford procedure, the dwell will be good to go.
10-24-2020, 09:03 PM | #15 |
Has any one tried one with the dwell points inoperative.
Lawrie |
10-25-2020, 08:06 AM | #16 |
I've done it,but with a 12v modern coil and appropriate ballast resistor. Worked fine...as expected since it is really the same as a later single point distributor. I figure Ford used the dual points and extended dwell time to compensate for the barely-adequate coils of the time. Terry
10-25-2020, 10:15 AM | #17 |
A person can get better rpm response from a dual point set up. Mallory was still selling quite a few aftermarket units for all V8 engines well up into the early 70s. It was not a major upgrade but it could make some difference on the higher reving engines in the muscle car era.
