Old 10-06-2021, 04:09 PM   #21
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Antique Engine Rebuilding
Originally Posted by Big hammer View Post
Hoping the new owner keeps AER name and web site, sounds like the new owner working with Rich it will flawless turnover
Yes, because that is about all you would be buying IMO. The experience that Rich has in his head from rebuilding that many engines is likely non-transferable to the new owner, ...and from my own experiences I can tell you that there is a huge learning curve that only comes from hands-on experience and learning from your failures.
Additionally, if the new owner already has a machine shop, then most of the equipment necessary to do the work would likely be duplicates, so not much to be gain from that.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-07-2021, 11:21 AM   #22
Russ/40
Russ/40's Avatar
Maybe the answer to my question is in the tread above, but I don't see it. I have recently purchased a nice set of little used AER rods, USA made, with the hope of using them sometime in a future build. Is AER the sole source for the inserts?
Russ/40 is offline   Reply With Quote
Old 10-07-2021, 11:33 AM   #23
denniskliesen
denniskliesen's Avatar
To my understanding, yes. And I believe the main inserts also. You might try one of the vendors though. I believe Snyder’s are different. Best answer would be to call AER and ask them or order them if you know the size you need.
denniskliesen is offline   Reply With Quote
