Old 05-09-2021, 11:51 PM   #1
31 Woody
31 Woody's Avatar
Default Cleaning a gas tank
A friend of mine inherited a roadster from his grandfather. He has been working on it and took a look at the gas tank. He said it appears to have a brown sediment around the fuel cap opening. Any suggestions on cleaning the tank without removing it? Any good suggestions to see if the brown sediment is soluable without damaging the rest of the tank?
Experience is a cruel teacher. It gives the exam first, then the lesson.
31 Woody is offline   Reply With Quote
Old 05-10-2021, 04:09 AM   #2
shew01
shew01's Avatar
Default Re: Cleaning a gas tank
Try “search.” There was a recent thread on this topic. Short answer, probably not.
shew01 is offline   Reply With Quote
Old 05-10-2021, 04:50 AM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Take a sample of the brown sediment by rubbing your finger. Then determine if the sediment is organic or rust. If rust, my prediction is this is one of many areas that has rust forming. If so, the tank must be removed to be properly restored.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-10-2021, 10:59 PM   #4
CWPASADENA
CWPASADENA's Avatar
I have had VERY GOOD success cleaning out Model A Gas tanks without removing them.
I first use a product called Metal Kleener 2014 which will usually clean out all the old dried up deposits and general crud.
If after that and it is found that there are some rust deposits, I then will use RUST 911 to remove the rust deposits.
These products are available on line directly from the manufacturer rust911.com
There is no need to remove the tank. These products are bio degradable and will not harm the paint. If I do get some on the paint, I immediately wash it off with soap and water just to be sure but I have never had it harm the paint.
These products may not work for every situation but I would first give it a try before I would remove the tank, take it to a shop to do the work, have the tank re-painted and then put it back in the car.
That is what I would do.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 05-11-2021, 05:16 AM   #5
shew01
shew01's Avatar
Here are some links I found. Maybe some of the posts are helpful.
https://www.fordbarn.com/forum/showt...clean+gas+tank
https://www.fordbarn.com/forum/showt...oval&showall=1
https://www.fordbarn.com/forum/showt...s+tank+removal
Old 03-04-2022, 08:00 PM   #6
Stimeyva62
Thank you for the information. That is what I am going to try first
Stimeyva62 is offline   Reply With Quote
