Old 02-01-2021, 02:55 PM   #1
hombres ruin
hombres ruin's Avatar
Default Napa part number for 41 fan belt
Can anyone tell me what the Napa part number is for a fan belt for a 41 ford coupe? Stock pulleys,6 V 42 generator. I have one from C&G it’s V shaped with ridges.
"I have built my organisation on fear"..Al Capone.
hombres ruin is offline   Reply With Quote
Old 02-01-2021, 03:13 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Napa part number for 41 fan belt
Don't know what you mean by "V shaped with ridges"
The belts are supposed to be 'V' shaped and some have relief grooves.
The belt should be 54 3/8"long x5/8" wide.
Check Napaonline.
Old 02-02-2021, 08:10 AM   #3
BobR35
BobR35's Avatar
Not sure if it's the same as my '35 = NAPA B54. It's 56 3/4" long.
BobR35 is offline   Reply With Quote
Old 02-02-2021, 01:51 PM   #4
Joe Immler
I have a DAYCO No. 22528 belt on my '41. It fits perfect and has been on for 7 years now.
Joe Immler is offline   Reply With Quote
Old 02-02-2021, 01:54 PM   #5
wamnram
wamnram's Avatar
I forget who this came from, somebody here on the Barn nice enough to share it.
Wayne
wamnram is offline   Reply With Quote
Old 02-02-2021, 01:59 PM   #6
marko39
It is easy to figure, B(size ) plus 3" equals true length. Thus a B54 measures about 57".
marko39 is offline   Reply With Quote
Old 02-02-2021, 02:20 PM   #7
Ziggster
Not sure if the 41 belt arrangement is the same as I have for my C59A, but for the crank/water pump/ generator belt I went with the Gates B54/55 belt. My crank pulley is no good so I can’t fit it onto the crankshaft to get an exact fit, but I think either will work with the generator adjustment range.
Ziggster is offline   Reply With Quote
